Thread: Ignition key release?
Results 1 to 8 of 8
  1. #1 Ignition key release?
    gardner,mass
    So im having issues where I lost my original key on my 04+ gp and I took the key taped to the passlock 3+ in hopes it would start my car but my remote start just wouldn't work anymore. Well now my key is stuck in the ignition and I cant start the car due to a security lock. I have tried everything I can think of as far as security relearn, draining the power, tapping the cyl in hope it just stuck, ect.
    Well now my biggest issue is getting the key out of the ignition so I can get a new key made and do the security learn.
    On the 04+ there is no manual key release override. So how do these switches work? I assume there is a pin that is sent power to release the key and if I can figure out what pin that is then I can find the wire under the dash and put direct power to it.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  2. #2 Re: Ignition key release?
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    is there a little plug under the key ? there is on mine.remove the plug and stick a nail or something in there to hit the solinoid
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  3. #3 Re: Ignition key release?
    gardner,mass
    Like I said not on the 04+
  4. #4 Re: Ignition key release?
    gardner,mass
    Tried a new battery for ****s and giggles no luck. I just dont understand why the key is stuck. Idk if its part of the security lock out or if its due to something else.
  5. #5 Re: Ignition key release?
    GTP Level Member simbah's Avatar
    Lala land
    Is the little plastic ring with the letters ACC OFF ON START on it installed on the ignition switch?
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  6. #6 Re: Ignition key release?
    gardner,mass
    Finally had time today to sit down clear headed and think about the issue. I had thought that the security lock had nothing to do with the key being stuck from the beginning but wasnt sure. I was then thinking about how the 04+ cars have 2 cables going to the shifter, 1 for the gear select and the other i was unsure. So after taking a look that secondary cable sure enough is for the key release. When i had reinstalled the the shifter i was having a hard time reconnecting the that cable because the little adjuster on it had been pushed down ever so slightly so even though the car was in park and indicated park on the hud, the key release cable was acting as in reverse. A slight adjustment and the key came out and i also got a new key made threw the dealer and a new key fob for dirt cheap. Tonight ill retry a security learn with the new key and hope she starts.
  7. #7 Re: Ignition key release?
    congrats. i just learned something new myself.
  8. #8 Re: Ignition key release?
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    gin; perseverance pays off.
  1. Zip Tie Key Release Button
    By SubwayGuy in forum General Grand Prix Discussion
    Last Post: 04-19-2015, 06:33 PM
  2. Ignition Switch Won't Release Key 2001 GTP
    By Comanche1959 in forum General Tech Discussion
    Last Post: 01-04-2013, 07:08 PM
  3. Key release
    By Jay7199 in forum General Tech Discussion
    Last Post: 06-16-2011, 12:28 PM
  4. Key stuck in ignition & shifter wont release!!
    By Pontiac 2003 in forum General Tech Discussion
    Last Post: 04-03-2010, 12:54 PM
  5. 2002 won't release key from ignition
    By BLOWN93LX in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-03-2009, 02:04 PM
