Thread: Auto delay headlights?
Results 1 to 5 of 5
Carbon Summit Auto delay headlights? 10-09-2009, 09:57 PM
mikedinthecity Re: Auto delay headlights? 10-10-2009, 12:39 AM
Carbon Summit Re: Auto delay headlights? 10-11-2009, 10:57 AM
Carbon Summit Re: Auto delay headlights? 10-11-2009, 11:07 AM
Carbon Summit Re: Auto delay headlights? 10-11-2009, 11:33 AM
  1. #1 Auto delay headlights?
    South Dakota
    I don't have auto delay headlights on my GP so I thought I'd try to figure out if I could add it to my car. I looked through the manual and I don't see that its even an option in 2000.
    Did any 99-03 GPs have auto delay headlights? By auto delay headlights I mean when you shut the car off the headlights stay on for a period of time you set it for. My Denali has it and I really like it and it would be handy at times.
    If any GPs had it, what would it take to add it to my 2000 GP SE?
  2. #2 Re: Auto delay headlights?
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    i have a 00 and i also wouldnt mind these if you find out how or do lemme know. someone told me that the length of time the headlights stay on is programmed in the remote for the entry/alarm, but i didnt believe them. curious myself =)
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  3. #3 Re: Auto delay headlights?
    South Dakota
    I've been thinking about this a little and found that the 2000 Pontiac Bonneville has twilight sentinel so what would I have to take from a Bonneville and adapt into my GP to make this all work?
    So what makes this twilight sentinel work is the question?
    http://www.extendedgmwarranty.com/ow...Bonneville.pdf
  4. #4 Re: Auto delay headlights?
    South Dakota
    I just looked through the 2003 manual thinking the newer GPs may have gotten the option but now luck. It looks like we have to go outside of the GP family to rob parts. Maybe a Buick would offer and easier to adapt part than the Bonneville part. Not sure this is all just a starting place.
    If anyone has knowledge how the twilight system works and what parts are needed to make it work let me know.
  5. #5 Re: Auto delay headlights?
    South Dakota
    I was reading on a Buick site and there was talk of maybe having to reprogram the BCM to add it to a Buick that didn't come with it to accept it. I'm afraid if that is needed I'll be out of luck since there was never an option to have it on the GP where as with the Buick it was an option and uses the same harness, just a matter of telling the BCM that its on the car.
    I don't know any of this to be sure, just the way one post read. I've read plenty of posts online that were wrong, so this could be wrong too!
  1. Display Delay at Start Up
    By darinparsons99 in forum General Tech Discussion
    Last Post: 11-12-2009, 11:52 AM
  2. Exterior Lighting Delay Question
    By brian0488 in forum General Tech Discussion
    Last Post: 02-13-2009, 09:01 PM
  3. disabling auto headlights
    By Jakegday in forum General Tech Discussion
    Last Post: 11-15-2008, 01:23 PM
