Thread: 05 GP Front Speaker Replacement Issues
Results 1 to 4 of 4
Poseidon215 05 GP Front Speaker... 09-16-2015, 09:00 AM
simbah Re: 05 GP Front Speaker... 09-16-2015, 03:31 PM
Dancing Bear Re: 05 GP Front Speaker... 09-23-2015, 05:57 PM
Poseidon215 Re: 05 GP Front Speaker... 09-24-2015, 12:41 AM
  1. #1 05 GP Front Speaker Replacement Issues
    Ohio
    Ok so I have been slowly upgrading the audio system in my car. I have a base GP no monsoon system. I recently put in
    Kenwood DNX692
    Rockford P165-SI 5 1/2" Components
    Rockford P1692 6x9
    I used a PAC module for wiring and metro adapters for the speaker connections. Now the rears sound great. Less bass but better mids and crisp highs which is what I want since I will be adding a sub and amp soon. The fronts however sound awful. They are components with a built in crossover. I can't turn the head unit up past like 10 without them distorting bad. These are brand new so I doubt they are bad out of the box so something has to be off. Anyone have any ideas?
  2. #2 Re: 05 GP Front Speaker Replacement Issues
    GTP Level Member simbah's Avatar
    Lala land
    Do you have the correct polarity on your speaker connections
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  3. #3 Re: 05 GP Front Speaker Replacement Issues
    Jun 2015
    Clearwater, FL
    Shot in the dark here, but maybe one of the resistors in the crossovers was damaged somehow and its sending a full range signal to the tweeter? It would definitely cause massive distortion, but after looking at the speakers I'd be hard pressed to go that route. The crossover network is contained in the woofer. Who knows, I'd try hooking them up as the rears and see if you still get distortion. Could be a headunit issue.
  4. #4 Re: 05 GP Front Speaker Replacement Issues
    Ohio
    Got it all figured out today. I was about to just throw the old ones back in and send them back but I made up wires to go from the head unit to the speaker with it sitting in my lap and everything worked perfect. So I found that the adapter for the factory plug was backwards and reversed the polarity. Cut the connectors and put my own on there now everything is good to go.
  1. Front speaker replacement question.
    By gpbastard in forum Audio, Security & Visual Electronics
    Last Post: 11-05-2014, 09:08 PM
  2. Front door speakers and rear deck speaker replacement
    By Cruz in forum Audio, Security & Visual Electronics
    Last Post: 04-08-2013, 06:47 PM
  3. Speaker issues
    By 87IROCZOWNER69 in forum Audio, Security & Visual Electronics
    Last Post: 12-20-2011, 07:36 PM
  4. Front Speaker Replacement
    By itfrg in forum Audio, Security & Visual Electronics
    Last Post: 05-02-2010, 06:42 PM
  5. Speaker Replacement
    By nikkigpgt00 in forum Audio, Security & Visual Electronics
    Last Post: 03-02-2010, 10:00 PM
