Thread: 2000 Grand Prix GT aerforce gauge wiring help?
Results 1 to 12 of 12
  1. #1 2000 Grand Prix GT aerforce gauge wiring help?
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Hi I just bought dual aeroforce interceptor scan gauges for my 2000 Grand Prix and they don't turn on when you turn the car on I guess I have to hook them up to a acessory wire in the car because of the year of my car? Well as far as I've read you use the red wire on the extra plug they give you and hook it up to an acsessory wire anyone done this? Where did you hook them exactly? Help is appreciated thanks!
  2. #2 Re: 2000 Grand Prix GT aerforce gauge wiring help?
    Mar 2014
    Tucson
    Quote Originally Posted by Tonkin2000GT View Post
    Yep.
    Well as far as I've read you use the red wire on the extra plug they give you and hook it up to an accessory wire anyone done this?
    I did.
    I used a power drop harness to grab fused, keyed power. It's the unused plug hidden behind the glove box.
  3. #3 Re: 2000 Grand Prix GT aerforce gauge wiring help?
    Jul 2015
    Jamestown, NY
    Where exactly is that hidden plug? I've looked can't find it even pulled the carpet up is it safe to run it to the radio?
  4. #4 Re: 2000 Grand Prix GT aerforce gauge wiring help?
    Mar 2014
    Tucson
    Literally directly behind the glove box.
    Drop the glove box past the stops, and look for a white warning tag.
  5. #5 Re: 2000 Grand Prix GT aerforce gauge wiring help?
    Jul 2015
    Jamestown, NY
    Okay thanks you hooked it right to that wire? I have to remove the jumper on the back of the gauges do I cut it?
  6. #6 Re: 2000 Grand Prix GT aerforce gauge wiring help?
    Mar 2014
    Tucson
    I don't remember what I did on the aeroforce side. The instructions should lay it out pretty clear.
    I bought the drop harness from ZZP so I could plug into the drop without cutting/splicing any factory wires. If you don't want to spring for the $10 harness, you could just tap into the 12v power wire. Don't forget to put a fuse in the slot.
    Do you have a DVOM, or a 12v test light at least?
  7. #7 Re: 2000 Grand Prix GT aerforce gauge wiring help?
    Jul 2015
    Jamestown, NY
    Yea I was just checking it out on zzp was going to just buy it and do it correctly on the zzp plug do you just hook the red aeroforce gauge wire up to the red wire on zzp plug? Than just tape the 2 wires off?
  8. #8 Re: 2000 Grand Prix GT aerforce gauge wiring help?
    Mar 2014
    Tucson
    The tag on the harness should tell you what each wire is. I would still verify with DVOM or test light.
    Grab the 12v keyed from the harness. I think I may have grabbed the ground from the harness also. It's been a while... I then taped off whatever that third wire is. 12v constant, I think?
  9. #9 Re: 2000 Grand Prix GT aerforce gauge wiring help?
    Jul 2015
    Jamestown, NY
    Okay I found the plug under my glove box and just ordered the drop down harness from zzp there's no slack to really splice in I'd rather do it the right way. The aeroforce gauge instructions say hook the red wire to an acessory wire the other 2 wires on the plug for the aeroforce are for analog inputs. So on the zzp harness the 3 wires one is constant power, another is acessory power, and then a ground wire?
  10. #10 Re: 2000 Grand Prix GT aerforce gauge wiring help?
    Jul 2015
    Jamestown, NY
  11. #11 Re: 2000 Grand Prix GT aerforce gauge wiring help?
    I fvcking hate wiring gauges prolly explains why my wideband is still laying in the basement......
  12. #12 Re: 2000 Grand Prix GT aerforce gauge wiring help?
    Jul 2010
    Coquitlam,BC,Canada
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. 2000 Grand Prix Bose wiring diagram, woofers work, 6x9's not turning on
    By Xanthous in forum Audio, Security & Visual Electronics
    Last Post: 01-22-2015, 08:21 AM
  2. Replies: 0
    Last Post: 07-19-2012, 07:16 PM
  3. 04 Grand Prix gauge wiring help.
    By WayneG99 in forum Audio, Security & Visual Electronics
    Last Post: 06-28-2011, 03:03 PM
