Here ya go...you'll have to sort through it a bit but it hits on speaker sensitivity.
http://www.diymobileaudio.com/forum/...m-drivers.html
Here's the bread and butter:
Remember, most speakers are rated at 2.83V. A 4 ohm Speaker rated for 90db spl at 2.83v is really being rated at 2 watts! Whereas an 8 ohm Speaker rated for 90db spl at 2.83v is only being rated at 1 watt. You can do the math for yourself, Power = Voltage^2 / resistance. At 2 watts, we can assume that same 8 ohm speaker is actually rated at 93db spl (remember, every doubling of power gives you a theoretical 3db gain in spl). So using that 8 ohm speaker will give you the same amount of output, at half the power required as a 4 ohm speaker. Your amps run cooler and draw less power from your vehicle's charging system, your speakers run cooler, and everyone is happy!
