Thread: Adding remote start to 05' GTP, keys wrapped still?
Results 1 to 3 of 3
  1. #1 Adding remote start to 05' GTP, keys wrapped still?
    GXP Level Member
    Mar 2015
    Tomball
    Ok so I'm thinking of adding an alarm with remote start to my 05' and back in my day when we did remote starts on transponder keyed vehicles we would wrap wire around the ignition switch and then around the key which we would hide under the dash and add a relay that would cut the loop to keep the key from being "seen" by the ignition switch if the car was broken into and an attempt to start the car. Well that's been a number of years, and I remember when I got out of the business that Bus modules were starting to make an entrance into the market.
    Well it seems that every GP I have run into in the junkyard has had a key tucked into the dash. Is this still the way things are being done? What are you guys that do alarm installs using to bypass the factory anti theft without disabling it?
    thanks,
    Jeff
  2. #2 Re: Adding remote start to 05' GTP, keys wrapped still?
    Oct 2011
    Toledo, OH
    Being an 04+, see if you have the RPO code to be able to just add the factory option.
    7"
  3. #3 Re: Adding remote start to 05' GTP, keys wrapped still?
    GXP Level Member
    Mar 2015
    Tomball
    I am not sure how to do that, and I am actually more interested in adding an aftermarket alarm for the outputs and I like to keep the factory system intact as well. Even when I have done shaved door handles in the past I leave the door locks in place and functional.
    Jeff
  1. Adding remote start question
    By knightryda01 in forum General Grand Prix Discussion
    Last Post: 12-01-2014, 10:36 AM
  2. adding remote start to a 2006 base GP
    By silvervipertb in forum 04+ Specifics
    Last Post: 04-04-2012, 07:37 AM
  3. Car will not attempt to start and keys get stuck...
    By Levi in forum General Tech Discussion
    Last Post: 02-01-2011, 11:24 AM
  4. adding remote start to an 05
    By 05grandprixgt in forum General Tech Discussion
    Last Post: 02-01-2010, 08:15 AM
  5. Remote start with PassLock keys
    By brewtus in forum General Tech Discussion
    Last Post: 12-29-2009, 06:08 PM
