Thread: Want to wire in dash cam, what 12v wire?
Results 1 to 4 of 4
  1. #1 Want to wire in dash cam, what 12v wire?
    Donating Users
    Aug 2013
    Michigan, USA
    Most dash cam has auto power on when power is applied and off when power is cut (switches to internal battery for a few seconds). The front dash cam is easy, use add a fuse option and pick something in the fuse panel that doesn't use RAP. But the rear cam doesn't have convenient access to fuse panel and I don't want to run a wire all the way to the front.
    Is there a 12v power in the back somewhere that is on only when the key's on?
    2005 GP, 3.8, NA, and no compass module in the rear.
    TIA
  2. #2 Re: Want to wire in dash cam, what 12v wire?
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by genki View Post
    Basically, no.
    Have you installed an amp? Or have a factory amp? You might be able to pull power from it.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #3 Re: Want to wire in dash cam, what 12v wire?
    Donating Users
    Aug 2013
    Michigan, USA
    No amp of any kind, it's a former rental car so it only has standard no frill sound system. Guess I'll have to run a wire and tap into the fuse. Is there a guide for running a new wire from the front to the back while keeping it concealed? Like along the top?
  4. #4 Re: Want to wire in dash cam, what 12v wire?
    get a add a fuse put it in the wiper fuse, its off car off. then pop the door sils off and tuck the wire along the edge of the carpet, take the bottom of the back seat out, then run it at the side of the seats trip to the trunk. takes no time reall.
    back seat you grip and rip each side in the middle where you would sit in the back, its just a clip that holds the seat down, put your finger under the edge, pull up.
  1. Run wire from dash to back shelf
    By bluebsh in forum General Grand Prix Discussion
    Last Post: 05-08-2015, 06:48 PM
  2. Looking for some speaker wire and a new ground wire.
    By Bluemagic in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2013, 08:41 PM
  3. Replies: 3
    Last Post: 01-06-2013, 10:53 PM
  4. tach signal wire behind the dash?
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 06-28-2012, 08:24 AM
  5. Where is rear defogger relay wire? (and trunk relay wire)
    Last Post: 11-02-2011, 03:10 PM
