Thread: Serious Electrical Problems!!
Results 1 to 7 of 7
  1. #1 Serious Electrical Problems!!
    Mar 2015
    United States
    My 1997 GT has some serious electrical issues i try to turn on the a/c/heat on speeds 1-4 and it doesn't turn on instead it shuts off my head lights, but it'll work on 5 without shutting off my head lights. I don't know where to begin!! I almost forgot to mention that when i try to turn on the rear defrost they won't stay on long enough to defrost the window. and the function on the blower (i.e. front defrost, max a/c) it stays on front defrost and will not switch to anything else.
  2. #2 Re: Serious Electrical Problems!!
    Aug 2013
    arlington, tx
    Blend door actuator is your problem for blower issue. The other one, i'm not sure. Did this just spring up out of nowhere or have you done any work on the car lately?
  3. #3 Re: Serious Electrical Problems!!
    Ignition switch is your issue for the blower speeds/headlight shutting off.
    Went through the same problem with our 2002 GT.
    And when the ignition switch goes, everything will act wacky and strange, start there and see if anything else still is not working correctly. Rockauto sells a AC Delco brand switch for around 77 bucks.
  4. #4 Re: Serious Electrical Problems!!
    Mar 2015
    United States
    I'll have to wait and see I'm currently in the process of getting hired at autozone! That employee discount is gonna be great for parts!! Haha.
    Its been doing it since Ive bought it.
    Thanks for the help guys its been bugging me for the longest time!
  5. #5 Re: Serious Electrical Problems!!
    May 2015
    Colgate, WI
    Literally just had this issue! Definitely ignition switch replacement. Ignition switch assembly is around $75-$100. Or get it done in a shop for $200-$400 depending on your shop.
  6. #6 Re: Serious Electrical Problems!!
    i changed a ignition harness for a member here last fall, same problem for over ten years. its not all that hard to change.
  7. #7 Re: Serious Electrical Problems!!
    BrokeButRuns BadAssGTP02's Avatar
    Jul 2011
    Mass.
    Ignition switch is easy to do, I had the same issue on my 03, I'll find the thread I used that explains it perfectly and I'll send it to ya. It has pictures and so easy to follow. Took me like a half hour to do it all.
    Drunkie----- vtec = where 1 million unicorns fart at the same time at 5,500 rpms for extra powah
    Hardgainer-- yours looks nice and tight when I take a picture of mine it sags down..
    Me-- that's what she said lmao
  1. having some electrical problems need help please
    By ASHGTP in forum General Tech Discussion
    Last Post: 04-21-2014, 05:31 AM
  2. Electrical Problems
    By aksotap in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2011, 07:11 AM
  3. Few Electrical Problems
    By str3etgl0w in forum General Tech Discussion
    Last Post: 08-29-2011, 11:59 PM
  4. few electrical problems
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2009, 09:49 AM
  5. Electrical problems
    By Baumku in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2009, 09:31 PM
