Thread: TRS HID kit confusion. Wrong bulb?
Results 1 to 2 of 2
01GT guy TRS HID kit confusion. Wrong... 04-19-2015, 06:04 PM
SomeDudeAtHome Re: TRS HID kit confusion.... 04-23-2015, 09:52 PM
  1. #1 TRS HID kit confusion. Wrong bulb?
    Jun 2013
    So recently I purchased a 9007/9004 HID kit from TRS and I was installing it and I looked at the lights and the wiring looked off but it fit in my housing so I put it in. Then when I went to wire the thing, it wasn't mathching up. The wiring coming out of the bulb looked like this :
    The wiring looks completely different than the DDM bulbs I have. I am wondering if they sent me the wrong bulbs? They sent me an adapter that should go from high beam female to molex male, which doesn't work. And that blue fitting that I'm holding in the picture connects to another high beam male end but the wires just lead to each other and nothing going to the bulbs, which seems really odd.
    I have another set of spare bulbs I ordered that should be here tomorrow so maybe those will be right. But do you guys think that they are the wrong bulbs? They work in the car, but the high/low beams don't work
    TRS HID kit confusion. Wrong bulb? Attached Images
  2. #2 Re: TRS HID kit confusion. Wrong bulb?
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    I'm not sure I can be much of a help but do you need the harness for the high beams TRS sells?
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  1. P0650 - Check Engine Light issue, bulb ok, low voltage to bulb
    By jasonnovak in forum General Tech Discussion
    Last Post: 10-08-2014, 10:01 AM
  2. header confusion.
    By kking89 in forum General Tech Discussion
    Last Post: 03-24-2014, 01:43 PM
  3. Spark Plug Confusion
    By Thexissilent in forum General Tech Discussion
    Last Post: 05-31-2010, 12:32 AM
  4. Confusion about Downpipes
    By SomeDudeAtHome in forum General Tech Discussion
    Last Post: 11-25-2009, 11:59 AM
  5. exhaust confusion
    By M.$tErNeR in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-16-2008, 09:15 AM
