Thread: 2007 GP Base radio replacement OEM
Results 1 to 8 of 8
  1. #1 2007 GP Base radio replacement OEM
    Jan 2015
    Earth
    On a base 2007 GP what other OEM radio would plug right in? The one the car came with is ok but the LED on the display is half burnt out and depending at what point it will REALLY annoy me I would want to swap it out. The car did not come with steering wheel controls but did have On Star installed after the fact.
    Thanks!
    Fidget
  2. #2 Re: 2007 GP Base radio replacement OEM
    theres a how to for replacing the bulbs in the radio display.
    if you do find a used radio you'll need to figure out how to unlock it so it works in your car.
  3. #3 Re: 2007 GP Base radio replacement OEM
    Jan 2015
    Earth
    Yes i did find a how to how to replace the bulb. I want to see what OEM radios are compatible for a possible upgrade to a am/fm CD player since If I put in an aftermarket radio that increases the chances of it being stolen. Not too many people are interested in stealing an OEM radio.
  4. #4 Re: 2007 GP Base radio replacement OEM
    that you can do, ( as long as its not a monson radio) the plugs are the same on the back. but you'll have to unlock it. ive seen youtube vids how to do it.
  5. #5 Re: 2007 GP Base radio replacement OEM
    GTP Level Member simbah's Avatar
    Lala land
    To unlock 04 and newer radios you have to take to a dealer, or someone with a Tech 2 tool, this is the only way to program a radio other than the one that came with the car. Unless of course you go the aftermarket radio route. Then no programming has to be done. The dealer will prolly charge around $100 for this service.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  6. #6 Re: 2007 GP Base radio replacement OEM
    Jan 2015
    Earth
    So say a "bowtie" radio that was in a 2007 G5 would work as shown here
    2007 GP Base radio replacement OEM Attached Images
  7. #7 Re: 2007 GP Base radio replacement OEM
    search for it on ebay, see if it crosses over as well, and you can see both radio backs and check what the plugs look like.
    i was looking for a radio for my friends exploder, its the same radio as 3 or 4 other cars, one being a mustang.
  8. #8 Re: 2007 GP Base radio replacement OEM
    Nov 2015
    Bethel, OK
    Sorry to hijack here, but does anyone know if this style will plug and play in an older model like my 2004? Or does anyone know if GM made a radio for my 2004 with an auxiliary port? thanks
  1. 2007 prix radio replacement
    By DaveMK1 in forum Audio, Security & Visual Electronics
    Last Post: 03-23-2013, 06:40 AM
  2. 2007 GP Base
    By jlgp2007nc in forum Members Rides
    Last Post: 03-07-2013, 01:16 PM
  3. Went from 2007 Base to 2008 GXP
    By jeangreyfan in forum Members Rides
    Last Post: 05-12-2012, 11:45 PM
  4. 2007 Base vs 1999 GTP
    By Brien in forum Off Topic Discussion
    Last Post: 12-24-2010, 01:02 PM
  5. 2007 GP Base Radio GM12-Auxv2 - Compatible?
    By njosephs69 in forum Audio, Security & Visual Electronics
    Last Post: 05-03-2009, 01:41 PM
