Thread: Coupe 6x9 and 6.5" in doors how to
Results 1 to 13 of 13
  1. #1 Coupe 6x9 and 6.5" in doors how to
    GT Level Member TwiztdWun's Avatar
    Feb 2013
    Ohio
    Just got done swapping in new speakers and wanted to fit 6.5" speakers in the doors to get rid of those anemic 5.25" speakers ( Yes, 6.5" speakers do fit....at least the Kappas will ). I used Infinity Kappas for the simple reason it is hard to find a better speaker in this range. There are better speakers, but, you go from $250-ish dollars for all four up to about $900-ish for all four.
    I also went coax instead of components as I am looking for better quality sound, but, I am not looking for competition sound. In short, my time was limited and I was not feeling overly energetic to go through the extra steps of running a proper component set.
    Now, different manufacturers use different baskets and throw depths for their speakers. The Kappas are fairly shallow. If you want to put 6.5's in the doors the simplest way, you can remove the OEM speaker mounts and with a little work, you can mount them direct to the door, but, you loose the angle up to your ears.....the sound just blows across your legs. I paid for the whole speaker and I want to hear the whole speaker.
    I have included instructions for both front and rears.
    Differences between the OEM and Infinity Kappas. Slight upgrade in quality:
    For the rears, take the lower seat bottom out.
    Then you have 4 nuts to remove from the seat backrest ( Two on each side ). You will need a 10mm and 18mm socket for this.
    Remove both inner side panels. These just pop in and out. You do not need to remove the door sill molding. They will slide in and out with no problems:
    Next, remove the clothes hanger brackets from the C-Pillar moldings. They just pop out with a flat blade screwdriver:
    Next, pop the rear of the C-Pillar molding loose and wrap around and down to where it touches the back of the seat rest support. It will stay in place and give you plenty of room. You do not need to remove the molding:
    There are 2 black plastic lock tabs that need to be removed form the rear deck cover. Once those are removed, lift up on the cover and pull it forward. If it doesn't come forward, you aren't lifting up on it enough. There are bolts on the bottom of the cover that catches the speakers. You have to clear those:
    Once this is done, you just remove the speakers. I took out the 4" speakers as they are completely useless......plus, in theory, I may grab a little extra bass from the trunk this way.......and the weight saving of leaving those 4" speakers out means I will probably pick up a couple tenths in the 1/4 mile:
    Here it is with the new 6x9's in place. I aimed the horns to the outer edges as in theory, it will help the highs wrap through the car rather than just be focused into the center of the car.
    For the fronts, Remove the door panels. It also would be smart if you have some new nylon panel tabs to replace the ones you are going to break or strip when you pull the doors off. You will want to remove the speaker and speaker mount.
    If you drop the bigger aftermarket speaker in the mount, as you guessed, the results are expected.
    Front of speaker mount before modification:
    This is everything I had to remove to make the speaker fit flush:
    This fits with perfection. The edge of the speaker just touches the support shelf on the door. The only way to move the speaker higher would be to remove metal from the door.
    The bottom two mounting holes on the speaker extend beyond the mounting surface of the speaker mount. This is an easy fix.....bend the tabs over the edge and run your mounting screws in. If you position it just right, it will be a flush fit. If not, just angle the screw away from the speaker slightly and it will pull flush and be extremely rigid:[
    Replace the door panels and you are done. Enjoy your much upgraded sound.
    Official GPF Red Neck
  2. #2 Re: Coupe 6x9 and 6.5" in doors how to
    You did a lot of extra work do get to the 6x9s, you dont have to remove anything except the rear seat and the rear deck cover. So you didn't have to remove the rear side panels or the c pillar.
  3. #3 Re: Coupe 6x9 and 6.5" in doors how to
    Feb 2013
    Ohio
    To me it just makes it easier to remove them. Plus, on a car this old, that speaker panel is probably rotted and will crack/break easily wrestling around the panels. I hate hacking around stuff.....especially when you cant get those parts anymore if you break them. It literally only takes a couple more minutes to do it this way and much better than breaking that panel and my OCD bothering me about it.
  4. #4 Re: Coupe 6x9 and 6.5" in doors how to
    Hmm on my 01 GT and my 97 GTP the rear window panel came out easy as pie, no way they would have broke.
  5. #5 Re: Coupe 6x9 and 6.5" in doors how to
    Feb 2013
    Ohio
    Well, that's cuz your a hack and like to ape on stuff.
  6. #6 Re: Coupe 6x9 and 6.5" in doors how to
    yup. i just took the whole back seat out, then the 3 push clips lifted the deck cover unhooked my 3 rd brake light, and slid it out.
  7. #7 Re: Coupe 6x9 and 6.5" in doors how to
    Feb 2013
    Ohio
    And your a hack, too. And there is no unhooking third brake light. You don't even touch that. And its 2 plastic tabs not 3. Are you sure we are talking about the same car?
  8. #8 Re: Coupe 6x9 and 6.5" in doors how to
    i do drive a regal ya know. my 3 rd brake lights harness plugs in under the rear dash cover on the pass side. my light is in the cover its self.
  9. #9 Re: Coupe 6x9 and 6.5" in doors how to
    All I did was take out the rear seat, remove those 2 little plastic clips and it slid right out.
  10. #10 Re: Coupe 6x9 and 6.5" in doors how to
    Feb 2013
    Ohio
    Mine wouldn't....it lays underneath the C-pillar and side panel molding by about 2" on each side. Trust me...I tried.
  11. #11 Re: Coupe 6x9 and 6.5" in doors how to
    Well that is weird.
  12. #12 Re: Coupe 6x9 and 6.5" in doors how to
    May 2014
    Flint
    If these would fit my 6.5 polks I would pay for these shipped
  13. #13 Re: Coupe 6x9 and 6.5" in doors how to
    May 2014
    Flint
    Anyone willing to ship a modified pair?
  1. SELL ME A 2.5" OR 3 " CATTED DOWNPIPE FOR L36 1998 GP GT Coupe!!
    By MrDniceL36 in forum Wanted To Buy - Parts
    Last Post: 10-11-2014, 10:08 AM
  2. SELL ME A 2.5" OR 3 " CATTED DOWNPIPE FOR L36 1998 GP GT Coupe!!
    By MrDniceL36 in forum Shops and Community Heroes
    Last Post: 10-07-2014, 12:48 PM
  3. Lambo doors on a GTP coupe?
    By otaku in forum Visual/Body Modifications
    Last Post: 05-25-2014, 10:33 AM
  4. 7" in front doors?
    By Carpepoon in forum Audio, Security & Visual Electronics
    Last Post: 01-16-2011, 02:37 PM
  5. 8" Comp Woofers in Doors?
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 01-15-2008, 01:33 AM
