I got the GMOS-01 because I don't have monsoon. I do have a question though on the wiring for this.
On the 16 pin connector it tells me to connect the red wire to the radios ignition power wire, but on the 16 pin connector I have two red wires coming out of it. which one, or both, do I use for this connection?
Also, I seem to have an Illumination wire, and a dimmer wire coming off of the 24 pin connector, and a dimmer wire coming off the 16 pin connector. The metra guide says to use the dimmer wire of the 16 pin connector, but my Aftermarket radio guide says it doesn't support dimmer settings, which leads me to believe i should be using the illumination wire off of the 24 pin connector, is that a correct assumption?
