Thread: 2004 GT Aftermarket Radio Install
Results 1 to 3 of 3
  1. #1 Re: 2004 GT Aftermarket Radio Install
    Is there a speaker in the middle of the dash if so you have monsoon if not then well you don't.
    GMOS-01 for non monsoon
    GMOS-04 monsoon
    The only function of the Dic that you'll lose is the date feature everything else will be fine.
    04 Comp G.
  2. #2 Re: 2004 GT Aftermarket Radio Install
    Oct 2014
    Canada
    I got the GMOS-01 because I don't have monsoon. I do have a question though on the wiring for this.
    On the 16 pin connector it tells me to connect the red wire to the radios ignition power wire, but on the 16 pin connector I have two red wires coming out of it. which one, or both, do I use for this connection?
    Also, I seem to have an Illumination wire, and a dimmer wire coming off of the 24 pin connector, and a dimmer wire coming off the 16 pin connector. The metra guide says to use the dimmer wire of the 16 pin connector, but my Aftermarket radio guide says it doesn't support dimmer settings, which leads me to believe i should be using the illumination wire off of the 24 pin connector, is that a correct assumption?
  1. NEED HELP! with 2004 Grand Prix after market radio install.
    By Trentonio in forum Audio, Security & Visual Electronics
    Last Post: 06-08-2016, 09:08 PM
  2. Aftermarket radio with HUD
    By YZ250rider in forum Audio, Security & Visual Electronics
    Last Post: 08-02-2012, 04:04 PM
  3. No sound after radio install..2004 Monsoon system. Need quick help
    By nickleahy23 in forum Audio, Security & Visual Electronics
    Last Post: 06-13-2012, 08:47 PM
  4. aftermarket radio
    By RedGrandprixgt53 in forum Audio, Security & Visual Electronics
    Last Post: 01-04-2012, 12:46 PM
  5. DIC not working after aftermarket radio install
    By rage03usa in forum Audio, Security & Visual Electronics
    Last Post: 08-30-2011, 10:39 PM
