i checked the inside fuse and relay and they look good. relay does not have much on the ohm reading...
Check the fuse with a test light or multi meter, just looking at them is not always good enough and swap the relay with another one from the car that is the same to eliminate that issue. If you flip the light switch on manually does it do anything?
