Thread: headlight/fog problem
Results 1 to 5 of 5
  1. #1 headlight/fog problem
    GT Level Member riceburner's Avatar
    Aug 2008
    denver, co
    THEY NO WORKIE!!!!
    but seriously, i had to jump my car the other night and i was using a 200A jumper box and now my headlights do not work...the turn and side markers work just not the headlights or fogs. i think i may have accidentally fried something when using my jump box?...all the other (tail, stop, turn and side) all work properly just the headlights and fogs?...anyone have any ideas? and do we have fuses anywhere but the main box in the engine bay?
  2. #2 Re: headlight/fog problem
    Aug 2008
    denver, co
    anyone?!?
    '01 GTP mods: K&N intake, autolite 104's, drilled 180*, !u-bend, !EGR, ported s/c, polished heads and TB and a LOT more whine
    '99 firebird mods (1 of 6): LS1 swap, custom exhaust, LS6 IM, RA intake, and a few suspension parts
  3. #3 Re: headlight/fog problem
    GT Level Member WhiteGT's Avatar
    May 2008
    Ontario
    I believe there is fuses in the glovebox on the passenger side. I have not needed to change any before but I think that's where I remember seeing them. Check your owners manual to be sure.
  4. #4 Re: headlight/fog problem
    Aug 2008
    denver, co
    i checked the inside fuse and relay and they look good. relay does not have much on the ohm reading...
  5. #5 Re: headlight/fog problem
    May 2008
    Ontario
    Quote Originally Posted by riceburner View Post
    Check the fuse with a test light or multi meter, just looking at them is not always good enough and swap the relay with another one from the car that is the same to eliminate that issue. If you flip the light switch on manually does it do anything?
  1. Headlight Schematics
    By SG2000GTP in forum General Tech Discussion
    Last Post: 12-12-2008, 03:32 PM
  2. Water in headlight...
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 10-14-2008, 03:37 PM
  3. My modified headlight!!
    By Malefic_GP in forum General Tech Discussion
    Last Post: 09-27-2008, 11:27 PM
  4. Headlight Adjustment
    By 97GP in forum General Tech Discussion
    Last Post: 08-17-2008, 11:28 PM
