Like I said the stock oem radio harness has a 12pin and a 24 pin, I know I will be using the 24pin connector but no where shows that I will be using the 12pin connector. What is that being used for now? Here is a picture of the oem harness http://www.installer.com/item/displa...p?it=71-2003-1
I Followed the axxess instruction and looks pretty easy but where it says connect A6 to an 12v accessory wire, do they mean to a power that is always hot? Or hot when key is in ignition like they mention in step 2 below?
1) Connect the Black wire of the ASWC-1 to chassis ground.
2) Connect the Red wire of the ASWC-1 to a 12-volt accessory wire, one that turns on and off with the ignition key.
3) Connect the Yellow/Green wire of the ASWC-1 to pin A7 of the vehicle.
4) Connect A6 of the vehicles harness to a 12-volt accessory wire.
5) All other wires on the ASWC-1 please tape up, they will not be used.
