K thanks will order the stuff, thinking of getting a double din from eBay something like this http://m.ebay.com/itm?itemId=321464454076. It's not my main car so looking not to spend alot of money on a double din with Nav, If you look at the description and scroll down until you see the wiring cables, number 1 is the iso adapter, I won't use the adapter I guess I would cut the wires and use what is needed. Only issue is ordering a no name brand double din is that I guess it's possible that the steering wheel controls won't work as the axxess harness can't detect the model of the HU? I would need to contact the seller to see if SW1 and SW2 means steering wheel control. Thanks for all of your help so far
