industrialfish
He said maximum aka peak. An amps peak is pretty much always more than double it's RMS anyway. Most 12V audio has an RMS rating for both subs and amps so match those up. You can blow a 2000w RMS sub with 500w RMS amp if you introduce enough clipping or too much gain or your ohms are mismatched etc.
To be blunt, you can safely run any wattage amp with any wattage sub if you know what you are doing. Safely, but not efficiently. A 20,000w amp going to a 200w sub is going to sound the same as a 200w amp going to a 200w sub if you properly set your gains.
