Thread: rms question
Results 1 to 10 of 10
  1. #1 Re: rms question
    GTP Level Member simbah's Avatar
    Lala land
    Charles "Chuck" McGregor, while serving as senior technologist for Eastern Acoustic Works, wrote a guideline for professional audio purchasers wishing to select properly sized amplifiers for their loudspeakers. Chuck McGregor recommended a rule of thumb in which the amplifier's maximum power output rating was twice the loudspeaker's continuous (so-called "RMS") rating, give or take 20%. In his example, a loudspeaker with a continuous power rating of 250 watts would be well-matched by an amplifier with a maximum power output within the range of 400 to 625 watts.[6]
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  2. #2 Re: rms question
    Dec 2013
    pulaski
    Quote Originally Posted by simbah View Post
    I just read the opposite, someone said make sure the driver could handle more than the amp so the sub doesn't blow.
  3. #3 Re: rms question
    Oct 2011
    Toledo, OH
    Quote Originally Posted by 98GtpONcrack View Post
    He said maximum aka peak. An amps peak is pretty much always more than double it's RMS anyway. Most 12V audio has an RMS rating for both subs and amps so match those up. You can blow a 2000w RMS sub with 500w RMS amp if you introduce enough clipping or too much gain or your ohms are mismatched etc.
    To be blunt, you can safely run any wattage amp with any wattage sub if you know what you are doing. Safely, but not efficiently. A 20,000w amp going to a 200w sub is going to sound the same as a 200w amp going to a 200w sub if you properly set your gains.
    7"
  4. #4 Re: rms question
    Dec 2013
    pulaski
    Quote Originally Posted by industrialfish View Post
    My problems is I have a 2500 watt RMS sub 5000 max. Its a dual 2 ohm and I wanna pick out a good amp but I'm not sure if I should get a 2500 RMS amp. Would that basically push the sub to the max? Then I know amps and subs are underrated most most the time, making it a little more confusing.
  1. To mod, or to rebuild? That is the question.. The $2000 question
    By comatoast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2013, 07:16 PM
  2. brake part question not completely noob question!!
    By Lastremanent in forum Introductions/Noob Questions
    Last Post: 06-11-2013, 05:18 AM
  3. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  4. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  5. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
