Thread: LED headlight/fog Conversion kits
Results 1 to 10 of 10
  1. #1 LED headlight/fog Conversion kits
    Jun 2012
    Cold Spring, MN
    Anyone have any experience with these or know which are the one's with a better reputation/reliability?
  2. #2 Re: LED headlight/fog Conversion kits
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    LED headlights = No
    LED Fogs = crappy light output usually for appearance only to match HID headlight color
    Unless you mean HIDs, if thats so then TRS, VVME, DDM are companies people like.
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: LED headlight/fog Conversion kits
    Jun 2012
    Cold Spring, MN
    I'm referring to conversion kits similar to HID conversion kits, not the poor quality universal LED foglights available off every parts store and Walmart shelf.
  4. #4 Re: LED headlight/fog Conversion kits
    Apr 2012
    Dayton, OH
    Link to the kits? I really dont know what your talking about. LEDs are just simple bulbs really don't need a conversion kit.
    2012 F150 STX
  5. #5 Re: LED headlight/fog Conversion kits
    Jun 2012
    Cold Spring, MN
  6. #6 Re: LED headlight/fog Conversion kits
    Pennsylvania, USA
    I wouldn't use those in your headlights. No matter how bright they are, the beam spread is going to be horrible, probably worse than HID's. The reason dedicated LED headlights are just showing up on newer model year vehicles is because of the amount of work that is needed to focus the beam properly.
    A kit like that may work decent in the fog lights because of the wattage, but keep in mind that the wattage does correlate to heat output to some extent. Don't want to go melting your fog light housings.
    It is confusing to me as to why they require ballasts though, and the description makes me laugh.
    • Super Bright! (Brigthter than typical HID Kits)
    In spite of that, the ballast says 1800 lumen (per bulb), whereas most 35w HID's put out 3200 lumen per bulb. Shady marketing right there.
  7. #7 Re: LED headlight/fog Conversion kits
    Apr 2012
    Dayton, OH
    For that price grab an HID kit from VVME, what nik said the scattering will be horrible because it will never line up like stock bulbs do just because how its designed.
    2012 F150 STX
  8. #8 Re: LED headlight/fog Conversion kits
    SE Level Member Rksqd1's Avatar
    Jul 2014
    St louis mo
    So should I stick to stock headlights for good vision? I really don't want to lose visibility. I do need to replace my headlights and I was looking at halo projectors.
  9. #9 Re: LED headlight/fog Conversion kits
    Apr 2012
    Dayton, OH
    The halo projector one piece deals are garbage don't waste your money, you can buy new housings to replace your old cracked hazy ones for like 60 bucks and just reuse your old brackets so they don't bounce. Or you can retrofit an actual projector into the housings and have amazing light output.
    Sent from the Milky Way
    2012 F150 STX
  10. #10 Re: LED headlight/fog Conversion kits
    Aug 2014
    around Milwaukee
    Quote Originally Posted by nik12937 View Post
    I had a spat with someone on a different forum for my Camaro regarding these LEDs and being retrofitted into old 4x6 sealed beam assemblies- I called him out on it as they were being marketed as DOT compliant.
    I have no information on the quality itself, just that the the layout of the LEDs does not faithfully mimic the light output of a filament.
    As for the "ballast", it is more of a driver to regulate the current going through the LEDs; as LEDs are current driven as opposed to voltage.
    Their resistance also goes down as they heat up which would allow more even more current to go through; this is known as thermal runaway.
    Having researched vehicle lighting for my projects over the last 20 years, I do not recommend any "conversion" kits. The only way to go is a retrofit where the bulb/reflector/lens assembly is integrated into whatever your vehicle has.
  1. Two Morimoto projectors one cup...uh...I mean headlight...headlight
    By RedDawnGXP in forum Visual/Body Modifications
    Last Post: 03-23-2011, 05:07 PM
  2. questions on HID conversion kits
    By duffman87 in forum General Tech Discussion
    Last Post: 06-22-2009, 09:35 PM
  3. HID Conversion Kits
    By DJFirestorm07 in forum Visual/Body Modifications
    Last Post: 11-25-2008, 12:40 PM
  4. 03-04 Land Rover Headlight Conversion DONE
    Last Post: 11-21-2008, 09:26 PM
  5. E85 Conversion Kits
    By Quicklynx in forum General Tech Discussion
    Last Post: 09-05-2008, 03:29 PM
