Thread: Pink wire
Results 1 to 3 of 3
  1. #1 Pink wire
    Aug 2013
    mpls, mn
    my bose system uses the pink lead to turn on outboard amp. i cut off the black plug and tapped into pink lead so my aftermarket hu would work. went back to stock and of course black plug was long gone. went to boneyard and got one. only a bose car has the pink lead. i assume most of the non bose hu also have the 2nd terminal pin out but it is not used. yard had a dozen grand prixs but only 1 had bose.
  2. #2 Re: Pink wire
    Feb 2014
    Grand Forks, North Dakota
    Maybe this will help, if you haven't figured it out already.
    40th Anniversary GTP. No name brand HAI. Partially clogged cat.
  3. #3 Re: Pink wire
    Aug 2013
    mpls, mn
    The 99 car uses a different main plug. Seems all the 99-00 cars HU has 2 rear terminals. I think around 01-02, GM went to the large single white plug. Seems my hu is a bit flaky. Volume is sketchy and dig display is skewed sometimes. Does work though. I got a double din hu from a 99 intrigue buried in my junk pile. Think they are very similar. Might be able to swap them. Gotta find it first.
  1. Pink Brake Light?
    By joeringo11 in forum 04+ Specifics
    Last Post: 06-25-2012, 10:30 AM
  2. Brandon's pink gp
    By mrlogic1234 in forum General Grand Prix Discussion
    Last Post: 04-15-2012, 03:03 PM
  3. Pink foam for a speaker box?
    By 99PontiacGTP in forum Audio, Security & Visual Electronics
    Last Post: 11-29-2011, 04:48 AM
  4. Hot Pink Paint Job ?
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 06-17-2010, 04:26 AM
  5. calling any pink flammed GPs
    By SlowM90 in forum Off Topic Discussion
    Last Post: 07-30-2009, 11:23 PM
