Thread: 1998 Grand Prix -- speaker changing suggestions
Results 1 to 6 of 6
  1. #1 1998 Grand Prix -- speaker changing suggestions
    SE Level Member TheNewNumber2's Avatar
    Apr 2014
    Panama City, FL (U.S.A.)
    One of my back seat speakers have been causing annoying rattles and distortion. I did a quick bit of research and pinned it down to two possibilities: either a damanged cone or the speaker is just loose.
    So, today I successfully, thanks to a handy Youtube video, removed the entire backseat assembly and go to the speakers. The foam is worn on all of them and starting to come off, but that's not my main concern right now.
    All of the screws were on tight. I found the offending speaker. When ever I pressed gently on the cloth skin covering the cone, the distortion would go away. I'm guessing the speaker is bad or something else aside from what I thought it was.
    I don't know the name of the speaker exactly, but I've circled it here in this picture:
    Since the form is badly worn and it's going to need replacing anyway one day, I decided to set about findign a replacement. That's where I ran into my problem.
    The speaker says Delco Electioncs Corp., which is now called AC Delco.
    The model number of the speaker was: 16207411 (LH)
    I quick search shows the part is no longer made. I didn't readily find one of eBay, thought I could have missed it since I don't know what the full unti looks like out of the car. But all the parts, when I skimmed the listings, kept coming back "used". I guess finding a "new" one might be hard, so without further delay:
    What now? Can I still get this speaker new someplace? What alternative speaker could I use (and will it work without having to also replace the one on the other side?)?
    I listen to a lot of film/television orchestral music and I find the Delco speakers were very suitable, though nothing remarkable, for my listening experience. So, if suggestiosn are made, keep in mind speakers that might be good for rap, pop, and one specifically for bass-heavy window vibrating experiences, are not what I need.
    AC Delco responded to my e-mail. They told me what I already knew and told them: the part is discontinued. They then suggested I try after market sources.
    They said there was no alternate part number. What??? Grand Prix was a popular seller. I see them on the road all the time. The years 1997 to 2003 (I think that's the number) have many parts that are similar if not interchangable. AC Delco never came up with an alternate part? This just strikes me as odd.
    I think it's even more odd to say "we show that GM has discontinued that part", when the part clearly says it was made by Delco. They have to go to GM to find out the part they made themselves, is no logner made? There's a saying for that: going through the back door to get through the front door. :P
    I don't want to be limited to a local store, both in terms of what I can get and what prices I will be forced to pay. I was hoping other people here might have gone through what I am going through.
  2. #2 Re: 1998 Grand Prix -- speaker changing suggestions
    SE Level Member A98GTP's Avatar
    Apr 2014
    Texas
    After market is the way to go. If I am not mistaking its a 4" and you can replace it with pretty much any brand. There are several options out there that sound as good or better than the OEM speakers. You will probably have to buy a pair, but they should be fairly inexpensive for an OE equivalent replacement such as a jvc or sony.
  3. #3 Re: 1998 Grand Prix -- speaker changing suggestions
    Mar 2012
    NC
    I ran Massive Audio 4's and 6x9's in the back of my GP and Massive Audio CK5 Stage III components in the front powered by a JL 300.4 amp. Sounded awesome. I still contemplate selling that stuff.
  4. #4 Re: 1998 Grand Prix -- speaker changing suggestions
    Apr 2014
    Is it necessary to replace both, or can I just do one and settle with the difference in sound on both sides?
    Thanks for the replies, guys.
  5. #5 Re: 1998 Grand Prix -- speaker changing suggestions
    Aug 2013
    McDonald PA
    Speakers normally come in pairs just do both
  6. #6 Re: 1998 Grand Prix -- speaker changing suggestions
    Do both. No sense in one of them sounding better then the other which will more then likely happen. Plus speakers aren't normally sold in singles.
    04 Comp G.
  1. new rear 6x9 speaker question and suggestions
    By des19 in forum Audio, Security & Visual Electronics
    Last Post: 07-10-2013, 04:04 PM
  2. Changing 04 grand prix heater core
    By PALMCASTER GT1 in forum General Tech Discussion
    Last Post: 12-27-2011, 09:52 PM
  3. 02 grand prix speaker mod
    By apierce1289 in forum Audio, Security & Visual Electronics
    Last Post: 08-23-2011, 08:27 AM
  4. Changing Spark Plugs on a 2004 Grand Prix
    By Clarkie59 in forum General Tech Discussion
    Last Post: 01-29-2011, 11:23 AM
  5. Changing my alternator 94 grand prix
    By bud6770 in forum General Tech Discussion
    Last Post: 05-10-2009, 11:51 AM
