Thread: Ok, what the f***!!!!`
Results 1 to 14 of 14
  1. #1 Ok, what the f***!!!!`
    Aug 2011
    Galveston
    whats up guys and gals ok this is my old audio setup i have 2 10" kicker cvr old model (grey and black) 4-ohm dvc
    amp: **** boss 3000.1 mono block. recently purchased a new amp SSL 3000.1 1-ohm stable (pretty good amp might i add)
    so everything has checked out fine sub-wiring ground power everything. WELL my problem is my system works when it wants too. I can take a quick trip to wal-mart and everything is good then when i get ready to leave no power to my amp. any suggestions
    Additional info.
    I have been installing audio systems for quite a while so i know how it all works.
    my subs 800 watts max i have a pair so that's 1600 watts my amp 3000.1 mono block 1-ohm stable brand new out of the box terminal seals and all. so with subs are currently wired 1-ohm load at the amp. i'm not at the battery terminal with Power wire i guess that could be part of the issue other than that i'm stumped also my old amp started to do this but that amp is 5 years old (IT WAS TIME) Thanks in advance
    Car Clean!!!! Keep Calm and Cruise
  2. #2 Re: Ok, what the f***!!!!`
    ... osiris94ej's Avatar
    Sep 2012
    Casper Wyoming
    Quote Originally Posted by ONEO View Post
    So your saying you don't have power wire ran to the battery?
  3. #3 Re: Ok, what the f***!!!!`
    Aug 2011
    Galveston
    Quote Originally Posted by osiris94ej View Post
    No im not and that's the crazy part about it before this issue i have never had this problem in any of my cars
    also the setup i have is the same setup i had for 3.5 years.
    oh oh oh and to mention i re-ran all of the wires except my antenna from the back of my radio new ground new power wire
  4. #4 Re: Ok, what the f***!!!!`
    Aug 2013
    arlington, tx
    So you really have about 800 watts RMS at your subs since max isn't the real number. Sounds like the amp might be too big for your subs and you might have a bad connection somewhere. Where did you ground your wires at? Why didn't you run your power wire all the way to the battery?
  5. #5 Re: Ok, what the f***!!!!`
    Aug 2011
    Galveston
    @ luckyg I have it ran to the fuse box power lead I have ran my trailblazer this way as well with no problems but different strokes for different vehicles my ground wire is on a default bolt on the Body of the gp shved the paint and added the nut and washer firmly the amp can be too big but i have it tuned to a low volume basically so i wont blow them but i think those are my only two options
    1.) Power Wire to Battery 2.) find a better ground..
  6. #6 Re: Ok, what the f***!!!!`
    Switch the power wire to the battery and not the fusebox. Every car is different and sure doesn't hurt to try it.
    04 Comp G.
  7. #7 Re: Ok, what the f***!!!!`
    Aug 2011
    Galveston
    exactly thanks for info fellas will try when i get off work
  8. #8 Re: Ok, what the f***!!!!`
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    I suggest you get a multimeter. Where are you getting the remote power? Stereo?
    When it goes out and doesn't want to work put the needles on the power and ground of the amp to see if there is voltage same with the remote wire.
    If You Cant Hear The Whine You're Too Far Behind...
  9. #9 Re: Ok, what the f***!!!!`
    Aug 2013
    Kitchener, Ontario
    Quote Originally Posted by GTP89 View Post
    I agree with this, could very well be the remote wire. If it won't power on, jump the remote by putting a wire from the power to remote. Not a permanent solution but you'll know right away if the remote trigger is the problem.
  10. #10 Re: Ok, what the f***!!!!`
    Aug 2011
    Galveston
    Done and done at battery im getting 14 and some change the same for the amp checked the ohms (speakers and amp) @ 1-OHMS turns out my remote wire basically i did a whole install new wires removed old wire and found out my remote wire fried not bad but it could cause me to lose power so its all new placemen of power wire is now connected to the batt (reason being that it fried due to the crappy amp) the amp has been around for a while i remembered my younger brother asking me man your amp havent burnt up anything in your car (clearly forgot) that was the same amp that my brother had when his system fried so.... new amp new wiring new everything except subs THANKS ALL
  11. #11 Re: Ok, what the f***!!!!`
    SE Level Member Prixer97's Avatar
    Jul 2011
    Fargo, ND
    What awg are you running to the box? Id start there, never cut corners do it right the first time id what I've learned. If pwr/rem check out, check voltage coming from the patch cables
  12. #12 Re: Ok, what the f***!!!!`
    Aug 2011
    Galveston
    Quote Originally Posted by Prixer97 View Post
    0 gauge power 4 gauge ground
  13. #13 Re: Ok, what the f***!!!!`
    Aug 2013
    arlington, tx
    Cool. Glad you got it fixed.
  14. #14 Re: Ok, what the f***!!!!`
    Aug 2011
    Galveston
    Quote Originally Posted by luckyg817 View Post
    Thanks.
