Quote Originally Posted by GTP89 View Post
I suggest you get a multimeter. Where are you getting the remote power? Stereo?
When it goes out and doesn't want to work put the needles on the power and ground of the amp to see if there is voltage same with the remote wire.
I agree with this, could very well be the remote wire. If it won't power on, jump the remote by putting a wire from the power to remote. Not a permanent solution but you'll know right away if the remote trigger is the problem.
