Quote Originally Posted by GTP89 View Post
I suggest you get a multimeter. Where are you getting the remote power? Stereo?
When it goes out and doesn't want to work put the needles on the power and ground of the amp to see if there is voltage same with the remote wire.
Done and done at battery im getting 14 and some change the same for the amp checked the ohms (speakers and amp) @ 1-OHMS turns out my remote wire basically i did a whole install new wires removed old wire and found out my remote wire fried not bad but it could cause me to lose power so its all new placemen of power wire is now connected to the batt (reason being that it fried due to the crappy amp) the amp has been around for a while i remembered my younger brother asking me man your amp havent burnt up anything in your car (clearly forgot) that was the same amp that my brother had when his system fried so.... new amp new wiring new everything except subs THANKS ALL
