Thread: Rear speakers
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
  1. #21 Re: Rear speakers
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    It bugs me to I can't go without them
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
  2. #22 Re: Rear speakers
    Is it safe to assume that you have a 97-98 GTP with premium sound non Bose? If so the rear 6x9s will not work with an aftermarket stereo. You will have to splice into the wires going into the 4" speakers and run them into the 6x9s.
  3. #23 Re: Rear speakers
    Jul 2010
    It's stock and not sure if it's premium or not
  4. #24 Re: Rear speakers
    It has 4" And 6x9s in the rear deck correct? So you are saying that you are still using the factory deck? If so then the factory amp under the dash might have gone out.
    Sent from A Galaxy Far Far Away........
  5. #25 Re: Rear speakers
    Jul 2010
    Yes it has smaller speakers beside the 6x9 speakers In the back so does that mean it has a factory amp?
  6. #26 Re: Rear speakers
    I am assuming so, the 8 speaker non Bose systems had an amp under the dash, at least my 97 did, and when I put in my aftermarket stereo I couldn't figure out why my 6x9s werent working, I even went out and bought new speakers thinking the factory ones were shot. Are you running the stock deck still?
  7. #27 Re: Rear speakers
    Jul 2010
    Yepp and were would it be?
  8. #28 Re: Rear speakers
    That I don't know. Look behind the glove box maybe. I am pretty sure you can find them on ebay. IIRC 97-98 cars were the only ones that had that amp, I think 99 was when they started putting Bose in them.
  9. #29 Re: Rear speakers
    Jul 2010
    Ok I'll pull the cover off and look in there and see if it has one and I thought when a amp died the sound would be screwed up
  10. #30 Re: Rear speakers
    From what I understand the amp only powers the 6x9s in that setup.
  11. #31 Re: Rear speakers
    Jul 2010
    Oh ok
  12. #32 Re: Rear speakers
    Jul 2010
    Slick2500 you were right I found the amp it has rust on it http://i1121.photobucket.com/albums/...psjyuufyqt.jpg
  13. #33 Re: Rear speakers
    Jul 2010
    http://i1121.photobucket.com/albums/...pscxjwxman.jpg
  14. #34 Re: Rear speakers
    Jul 2010
    Ok does the amp wires tie in with the radio harness?, mine has the plug for the cd changer but no changer, is it just prewired for one or is that the amp cause I'm buying a auxiliary kit that plugs in where the plug for the cd changer goes if that's not for the amp
  1. Help with rear speakers
    By Catfishking14 in forum Audio, Security & Visual Electronics
    Last Post: 07-09-2012, 01:02 PM
  2. Rear Speakers
    By 40thannPaul in forum Audio, Security & Visual Electronics
    Last Post: 05-19-2011, 11:31 AM
  3. Rear Speakers Don't Fit???
    By milo033 in forum Audio, Security & Visual Electronics
    Last Post: 01-03-2011, 04:53 PM
  4. Rear speakers cut out??
    By 91z in forum Audio, Security & Visual Electronics
    Last Post: 09-16-2008, 09:53 PM
  5. no rear speakers
    By 59chevy in forum Audio, Security & Visual Electronics
    Last Post: 04-15-2008, 06:44 PM
