Thread: stock monsoon cutting out at higher volume...
Results 1 to 8 of 8
  1. #1 stock monsoon cutting out at higher volume...
    Sep 2013
    Frederick,MD
    so about 2 months after i replaced rear speakers with the infinity ref 6x9..the amp seems to cut out at higher volumes,now i can leave it on a pretty high level and its fine,but if you turn it up it goes"click" and only thing left is my sub and rear tweeters...maybe front tweeter too,im not sure on the fronts.guess its a circuit
    breaker as it comes back on after awhile? is this the beginning of the end of my stock unit?
  2. #2 Re: stock monsoon cutting out at higher volume...
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
    In the stock Monsoon system, the rear speakers are driven by a left and right channel for the mid range speaker cones, and a subwoofer channel that drives both side's large cone. If you're replacing the OEM speakers with aftermarket, you've got choices - use the mids, use the subs, or tie both together. I tried all three and wasn't happy with the results. I think that the Monsoon amp has internal crossovers tuned for the OEM speakers.
    The same goes for the front. The two 6.25 speakers and the front door tweeters are both the same channels with crossover applied. What I never did figure out was the dash speaker.
    I scrapped it all in mine and replaced the Monsoon amp with a Pioneer four channel unit.
    I believe your amp is taking a dump.
  3. #3 Re: stock monsoon cutting out at higher volume...
    Sep 2013
    Frederick,MD
    i tied them all together by seperating the wires in the new speakers.i snipped the wires going to the tweets on the new speakers and the wires going to the woofer of the new speaker. so when i held the new speaker in my hand i has 2 sets of wires. by using the color code i wrote down prior to ripping things apart i was able to hook speakers up correctly. not a very good sound id say,but was def better than my popping and cracking i had prior to replacement. i might actually unhook them and crank it up and see what happens then..id really hate to have to dump the head unit and buy all those dam adapters needed. i really like the 6 disc changer..
  4. #4 Re: stock monsoon cutting out at higher volume...
    Aug 2012
    Fort Wayne
    I don't think your problem is in the head unit.
  5. #5 Re: stock monsoon cutting out at higher volume...
    Sep 2013
    Frederick,MD
    seems funny though i hook up new speakers and now theres an issue.maybe amp is workin to hard trying to push them? i got 2 ohm as the old ones were 2 ohm as well.. worse case maybe a 4 channel amp would be a solution..?
  6. #6 Re: stock monsoon cutting out at higher volume...
    Aug 2012
    Fort Wayne
    Quote Originally Posted by ddw350 View Post
    I don't have my old speakers anymore but I could have sworn they were four ohm. Four ohm Pioneer speakers is what I have installed in the four corners of my system.
    All in all, I think you'd be happier with an aftermarket amp, though I don't envy you the challenges of setting up one with the OEM head unit. With my Pioneer head unit, I was able to set up the crossovers within the head unit. When global warming ends, I'll tweak the settings on the amp, but even so, I now have a cleaner sound with oodles of volume compared to using the Monsoon amp. I have a Bazooka bass tube to supplement the bass, and I'm really happy with the results.
    Last edited by douger; 03-04-2014 at 09:57 PM. Reason: Edited to fix a badly mangled sentence.
  7. #7 Re: stock monsoon cutting out at higher volume...
    Sep 2013
    Frederick,MD
    so i unhooked the woofer part on both of the rear speakers and it seems fine. guess they are drawing to much current for the amp causing it to cut out? so now i have just the rear tweets..kinda "trebley" sounding but ill take that over the mess of a sound i had with the blown factory ones. i faded more to the front and switched the treble switch on the 6x9s so they arent super ear piercing and with the subs in the trunk it does good enough for now.yes i would hate to attempt a aftermarker amp with the stock unit..talk about time consuming... also is there a set of wires pre monsoon that would give full range? that might be a option to try as well?
  8. #8 Re: stock monsoon cutting out at higher volume...
    Aug 2012
    Fort Wayne
    Not that I am aware of. To install an aftermarket amp to replace the Monsoon amp and still retain the OEM head unit, you'd have to hack into the Monsoon amp's harness and still run a separate power feed to the trunk.
  1. Higher Drive Ratio... Stock Tune
    By 98grandamld9 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 04-06-2013, 10:02 PM
  2. New ZZP rear springs ride height question (higher than stock)
    By hifi dream in forum Brakes/Suspension/Chassis
    Last Post: 05-23-2012, 10:49 AM
