Quote Originally Posted by ddw350 View Post
so i unhooked the woofer part on both of the rear speakers and it seems fine. guess they are drawing to much current for the amp causing it to cut out? so now i have just the rear tweets..kinda "trebley" sounding but ill take that over the mess of a sound i had with the blown factory ones. i faded more to the front and switched the treble switch on the 6x9s so they arent super ear piercing and with the subs in the trunk it does good enough for now.yes i would hate to attempt a aftermarker amp with the stock unit..talk about time consuming... also is there a set of wires pre monsoon that would give full range? that might be a option to try as well?
Not that I am aware of. To install an aftermarket amp to replace the Monsoon amp and still retain the OEM head unit, you'd have to hack into the Monsoon amp's harness and still run a separate power feed to the trunk.
