Thread: dic clock with aftermarket radio
Results 1 to 5 of 5
  1. #1 dic clock with aftermarket radio
    Jan 2014
    NJ
    does anyone know a way to keep the clock working in the dic with an aftermarket radio like a module that transmits a time signal on the can data line?
  2. #2 Re: dic clock with aftermarket radio
    GTP Level Member simbah's Avatar
    Lala land
    What clock? Or do you mean the calendar? That is controlled by the factory Head unit and when replacing with aftermarket you will lose that function, no way around it. Besides you should have a clock on your new radio anyway.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  3. #3 Re: dic clock with aftermarket radio
    Jan 2014
    NJ
    sorry yes calendar and i'm looking at an x940bt so it has a clock, i just hate losing functionality, i wonder how hard it would be to come up with an ic to transmit the date on the can bus. has anyone tried or have any input?
  4. #4 Re: dic clock with aftermarket radio
    Pennsylvania, USA
    I remember seeing a write up a year or two ago on how to keep the calender, and it involved keeping the stock radio hidden in the trunk with wires run back to it. I can't remember specifics like what wires to tap into though, if I manage to find it I'll post a link.
  5. #5 Re: dic clock with aftermarket radio
    Jan 2014
    NJ
    Probably power ground and a can data line, im thinking we can probably make due with just the main board of the radio.
  1. Radio Station-Clock window does not illuminate
    By 02 GP GT in forum General Tech Discussion
    Last Post: 06-15-2013, 06:40 PM
  2. Radio clock wont display?
    By jayroca in forum Audio, Security & Visual Electronics
    Last Post: 03-24-2013, 05:23 PM
  3. Aftermarket radio in 08 GP?
    By bziggy58 in forum Audio, Security & Visual Electronics
    Last Post: 09-13-2011, 02:15 PM
  4. 1996 Pontiac Grand Prix SE radio/clock display
    By moospis in forum General Tech Discussion
    Last Post: 08-03-2011, 03:58 PM
  5. OEM Radio Clock stays on?
    By 100 BUX in forum General Tech Discussion
    Last Post: 03-16-2009, 01:58 PM
