Thread: 06 GXP w/monsoon radio upgrade
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21 Re: 06 GXP w/monsoon radio upgrade
    SE Level Member aeonaaron's Avatar
    Jul 2015
    So I'm pretty new to modifing car audio systems. Is their any way to add a sub to the already in place audio system?
    Sent from my SAMSUNG-SM-N910A using Tapatalk
  2. #22 Re: 06 GXP w/monsoon radio upgrade
    Jul 2015
    I'm speaking of the monsoon system, of course.
  3. #23 Re: 06 GXP w/monsoon radio upgrade
    SE Level Member rainmkr2's Avatar
    UpState, NY
    Did you go to the Crutchfield link about my car - http://www.crutchfield.com/learn/sho...grandprix.html
    It has some good information.
    Early on I successfully used a MTQ re-Q signal processor.
    The 6x9 are pretty much micro subs, they are wired together in parallel (if I remember correctly).
    So you can just tap into those wires off the Monsoon amp and send the signal over to the MTX re-Q.
    This method worked surprisingly well.
    I'd recommend adding a capacitor at each 6x9 if you go this route, they will block the low base and let your new sub do that work.
    Hope this helps.
    Pontiac - RIP 2009!!
    1998 - GTP - Winter
    2006 - GXP - Sping/Fall
    1991 - TA DropTop - Summer
  1. 2006 Pontiac Grand Prix Monsoon Stereo upgrade
    By madmex2k in forum Shops and Community Heroes
    Last Post: 12-02-2012, 05:30 PM
  2. Monsoon Rear Speaker upgrade and wiring??
    By fredfree in forum Audio, Security & Visual Electronics
    Last Post: 03-10-2012, 06:56 PM
  3. monsoon radio
    By 2005GrandPrix in forum Audio, Security & Visual Electronics
    Last Post: 02-14-2011, 09:35 PM
  4. '06 Factory Monsoon Radio INOP
    By CaptLively in forum Audio, Security & Visual Electronics
    Last Post: 05-07-2010, 07:39 AM
