So I'm pretty new to modifing car audio systems. Is their any way to add a sub to the already in place audio system?
Sent from my SAMSUNG-SM-N910A using Tapatalk
I'm speaking of the monsoon system, of course.
Did you go to the Crutchfield link about my car - http://www.crutchfield.com/learn/sho...grandprix.html
It has some good information.
Early on I successfully used a MTQ re-Q signal processor.
The 6x9 are pretty much micro subs, they are wired together in parallel (if I remember correctly).
So you can just tap into those wires off the Monsoon amp and send the signal over to the MTX re-Q.
This method worked surprisingly well.
I'd recommend adding a capacitor at each 6x9 if you go this route, they will block the low base and let your new sub do that work.
Hope this helps.
