Thread: Driver side rear lock not working
Results 1 to 13 of 13
Grandprix202 Driver side rear lock not... 01-19-2014, 07:48 PM
Phlip77 Re: Driver side rear lock not... 01-19-2014, 08:17 PM
Grandprix202 Re: Driver side rear lock not... 01-19-2014, 08:37 PM
bosull Re: Driver side rear lock not... 09-02-2014, 07:33 PM
Scottydoggs Re: Driver side rear lock not... 01-19-2014, 08:40 PM
Grandprix202 Re: Driver side rear lock not... 01-19-2014, 09:39 PM
Phlip77 Re: Driver side rear lock not... 01-19-2014, 09:37 PM
Scottydoggs Re: Driver side rear lock not... 01-19-2014, 09:50 PM
Scottydoggs Re: Driver side rear lock not... 09-02-2014, 08:19 PM
Grandprix202 Re: Driver side rear lock not... 09-02-2014, 08:20 PM
Scottydoggs Re: Driver side rear lock not... 09-02-2014, 08:23 PM
Grandprix202 Re: Driver side rear lock not... 09-03-2014, 11:23 AM
sn95gt50 Re: Driver side rear lock not... 12-30-2016, 09:34 PM
  1. #1 Re: Driver side rear lock not working
    Aug 2013
    Kitchener, Ontario
    I had that recently. I changed out the lock mechanism and still had the same problem. Turned out to be a broken wire in the loom from the door to the body.
    If it happens to be the lock actuator, it's one piece with lock mechanism. Not separate, at least on my car it was.
  2. #2 Re: Driver side rear lock not working
    GTP Level Member Grandprix202's Avatar
    Apr 2013
    Fowlerville
    Quote Originally Posted by Phlip77 View Post
    Ok... I would get back there and look around but the vapor shield (that plastic stuff) do I pull it back or what?
    Representing all the N/A out there. Fastest stock N/A you will ever come across.
  3. #3 Re: Driver side rear lock not working
    Apr 2012
    engelhard nc
    Can you access the wires inside the loom without taking off the door panel?
  1. Replies: 1
    Last Post: 10-02-2013, 07:52 PM
  2. How do I get at the driver's side power lock switche
    By Brian86 in forum How To Write-Ups/Tech Tips
    Last Post: 09-22-2013, 11:13 PM
  3. A/C working on passenger side not driver?
    By ntreftz in forum Shops and Community Heroes
    Last Post: 06-07-2013, 12:59 PM
  4. driver side parking and fog lights not working
    By shelbyguy04 in forum General Tech Discussion
    Last Post: 03-31-2013, 12:30 AM
