Thread: I need help and advice on installing a new deck. Please help!
Results 1 to 12 of 12
  1. #1 I need help and advice on installing a new deck. Please help!
    Jan 2014
    I'm looking into installing a new deck in my 06 Grand Prix, mainly because I want an AUX input in it. I hardly know anything about cars and I'm a broke college student on minimum wage.
    I'm wondering if anybody with experience can let me know if it's difficult to do my self and what will I need to install the new deck.
    I've called audio places and they're offering anywhere from $270-$320 for the job. I think that's ridiculous. I understand I need some kind of module and a deck kit which alone is worth 130 (from what I was told by the audio exoert).
    If anyone can help with resources or instructions on doing it my self I would appreciate it
  2. #2 Re: I need help and advice on installing a new deck. Please help!
    GTP Level Member
    Sep 2011
    Motown
    Go to crutchfield.com. Look for radios on there. Your going to want a double din cause a single din will just look foolish in the newer gen. I would recommend a pioneer avh-x3500bhs. But it's your car so pick what you would like. Then you will need to get the GMOS harness and then if you have steering wheel controls you will have to get another harness. To put the harnesses together with the car isn't hard, it's pretty self explanatory.
    Quote Originally Posted by deadwoodspecial View Post
    On a side note, I do want to add that Classy is keeping it classy through all of this. The guy has a hell of a business ethic, and is doing everything possible to make this right. If anyone was, is, or has considered getting retro's, I HIGHLY recommend him. Good prices, and he backs his sh!t.
  3. #3 Re: I need help and advice on installing a new deck. Please help!
    Jan 2014
    Thanks for the response. I'm definitely going to take the advice, however; I was wondering if the GMOS is hard to install? Do I have to cut any wires and reconnect them? Or is just a matter of snapping on the harness. I'm not gonna lie I'm pretty intimated with the whole installation. Is it as easy as it sounds. And is there a difference in the installing of a single din vs a double?
    Sent from my SGH-T999 using Tapatalk
  4. #4 Re: I need help and advice on installing a new deck. Please help!
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
    Quote Originally Posted by DonkeyKong View Post
    What you do with the GMOS adapter is splice it to the new head unit's harness. For the most part, the colors will match. When you do it this way, you'll be using the OEM speaker wiring, which will save you hours of time running wires to the different speakers.
    Take your time, check off on the wiring diagrams which wire you've hooked up, and for gawd's sakes, use a soldering iron and heat shrink and not butt splices.
    One note: do not hook up either the mute or amplifier turn on wires to the GMOS. If you use the GMOS adapter, it will run your audio output through the OEM amp if equipped. That's already switched through the ignition switch.
  5. #5 Re: I need help and advice on installing a new deck. Please help!
    Jan 2014
    Thanks man. I appreciate the reassurance. I'll definitely save at least 200 bucks doing it myself
  6. #6 Re: I need help and advice on installing a new deck. Please help!
    GTP Level Member
    Sep 2011
    Motown
    I have wiring instructions on my phone, Ill put a pic on here. Literally all you do is put right speaker wire from GMOS to right speaker wire on radio. Thats literally how it goes. It'll take an hour tops. But for the double din, a single din will look goofy in the 04+ cars. I mean its your car but I would honestly recommend staying double din. And heres a link you can get a great radio for cheap. Its used but its basically brand new.
    http://www.grandprixforums.net/showthread.php?t=84686
    you honestly cant pick up a radio like that for that price. Its a good deal! I would recommend it!
  7. #7 Re: I need help and advice on installing a new deck. Please help!
    Quote Originally Posted by Classy Pontiac View Post
    I agree with this guy!
    04 Comp G.
  8. #8 Re: I need help and advice on installing a new deck. Please help!
    SE Level Member Peirce1970's Avatar
    Myrtle beach, S.C.
    Take your time and remember the wire colors on the harness match the colors on the deck. There are 2 diffrent GMOS harnesses for these cars. The GMOS-01 is for non amplified factory systems and the GMOS-04 is for the amplified systems which is the monsoon system. The best price I've found for these are on amazon.
  9. #9 Re: I need help and advice on installing a new deck. Please help!
    Dec 2012
    troll land
    You can get the adapter at walmart for like $40-$60
  10. #10 Re: I need help and advice on installing a new deck. Please help!
    or you can add one to a stock radio for 5 bucks in parts. yes ive done this, nd a bunch of others have also. http://ls1tech.com/forums/stereo-ele...t-adapter.html
  11. #11 Re: I need help and advice on installing a new deck. Please help!
    Jan 2014
    Thanks everyone for the advice and information. I'm glad I decided to ask on the forum before I took it to an audio shop. It wasn't as difficult as I taught. Saved money doing it myself. Thx again fellas I appreciate the help!
  12. #12 Re: I need help and advice on installing a new deck. Please help!
    GT Level Member Hardonyomom's Avatar
    aurora
    You can't go wrong with the pioneer deh 80 prs. I put that in my 01 with bose and it really made it come alive. It has a 16 band eq on it also!
  1. DIC Funtions after Installing Aftermarket Deck
    By extreme in forum Audio, Security & Visual Electronics
    Last Post: 09-08-2012, 04:05 PM
  2. stock deck vs aftermarket replacement advice
    By NAC in forum Audio, Security & Visual Electronics
    Last Post: 08-24-2012, 07:59 PM
  3. Installing a aftermarket deck on a Bose system.
    By Pontiacman76 in forum Audio, Security & Visual Electronics
    Last Post: 09-07-2011, 09:19 AM
  4. Help installing deck
    By kamikaze275 in forum Audio, Security & Visual Electronics
    Last Post: 09-07-2009, 08:17 AM
  5. advice on installing third set of lights
    By mhoran89 in forum Visual/Body Modifications
    Last Post: 06-28-2009, 04:24 PM
