Thread: radio wiring harness
Results 1 to 6 of 6
  1. #1 radio wiring harness
    Dec 2013
    Leavenworth, KS
    I am getting a new radio come tax time. and i was wondering. on the wiring harness, do i need to buy the expensive one even tho i dont use the onstar?? or will the cheap one work?? wat all have you guys done and/or can someone direct me in the right direction. Thanks guys!!!
  2. #2 Re: radio wiring harness
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
    The year of your car would be a big help, but generally, if you don't want to run speaker wires, get one of the adapters.
  3. #3 Re: radio wiring harness
    Dec 2013
    Leavenworth, KS
    Its an 04 and ya im going to get one. But im wondering if the cheap one like you can get at wallmart will work. Or if i have to buy the one to make onstar work. I dont plan on using it at all
  4. #4 Re: radio wiring harness
    Aug 2012
    Fort Wayne
    Quote Originally Posted by SSGP View Post
    I used the GMOS-04 adapter ostensibly to keep the OnStar. I might have been better served using the -01 adapter instead. My original intent was to keep the Monsoon amplifier together with the chimes. (I sometimes forget to turn the turn signal off.) If you're not going to use a separate amp and reuse the speaker wiring that's already there, get one of the adapters. If you're going to use features like a back up camera, get the adapter. To me, it's worth every penny to eliminate the extra work and frustration that it takes not to use them. Your mileage may vary.
    If you do not have a Monsoon amp, I think it takes another adapter. You'll need to do your homework as to which one. Also, some people here have reported "gremlins" introduced by the Metra adapters interfacing with the serial data stream. My first one would intermittently keep the engine running while the retained accessory power (RAP) was on and the key off. There are other adapters out there if that's a concern.
  5. #5 Re: radio wiring harness
    Dec 2013
    Leavenworth, KS
    Okay. Ya i dont have the monsoon system. And eventually i want a back up camera but i beleive the radio im getting has the wiring already part of it. But im not sure. Ill do a little more research and see wat will be better
  6. #6 Re: radio wiring harness
    Just stick with a double din headunit and thank me latwr
    04 Comp G.
  1. Radio Wiring Harness
    By MikeW420 in forum Introductions/Noob Questions
    Last Post: 09-04-2013, 11:31 AM
  2. What is the cheapest radio wiring harness - 2006 GT no Monsoon & no On-Star
    By nickbuol in forum Audio, Security & Visual Electronics
    Last Post: 03-05-2011, 11:23 AM
  3. Need some help, wiring harness meltdown! have some harness swap questions for a guru
    By pureroundcircle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 09:23 PM
  4. zzp wiring harness
    By TheOtherNick in forum Audio, Security & Visual Electronics
    Last Post: 11-03-2008, 02:47 PM
