Thread: prj wires and more
Results 1 to 10 of 10
Golgo13 prj wires and more 12-23-2008, 03:22 AM
gtpinsc Re: prj wires and more 12-23-2008, 10:40 AM
reinke Re: prj wires and more 12-23-2008, 11:54 AM
gtpinsc Re: prj wires and more 12-23-2008, 01:22 PM
Golgo13 Re: prj wires and more 12-23-2008, 01:23 PM
Toofastgs Re: prj wires and more 12-23-2008, 01:52 PM
Golgo13 Re: prj wires and more 12-23-2008, 07:48 PM
offroadfury6 Re: prj wires and more 12-23-2008, 06:16 PM
gtpinsc Re: prj wires and more 12-23-2008, 07:07 PM
offroadfury6 Re: prj wires and more 12-23-2008, 08:23 PM
  1. #1 prj wires and more
    Oct 2008
    mascoutah, Il
    are the prj wires known to cause alternator whine? If not I have a couple other questions.
    I also have a constant high pitched whine coming from my tweeters. without the car running, just anytime the hu is on. Originally thought it was the polk momos that were in the car, turns out not but they were shot anyway. Replaced with infinity perfects.
    Discovered when the mtx 4 channel was switched to low pass the noise disappeared. So I was now sure it was coming through the tweeters. Replaced rcas and relocated chassis ground, no luck.
    Going to try to use a old eclipse amp i have laying around, if still no luck I'll rewire the speakers with new wire and see what happens.
    I am using an old pioneer premier hu, but I have had no problems with it before. I have heard pioneer decks like to have and extra ground attached to the rcas or the radio chassis but I'm not sure if thats the case.
    Am i missing something?
    2002 GTP
    custom HOK paint
  2. #2 Re: prj wires and more
    Jul 2008
    sumter,south carolina
    I had a similar problem with my subs and sub amp,turned out to be the amp itself.Some how a resistor fried and was causing feedback to subs.Id try switching amp out and go from there.If its a resistor MTX should be able to fix it for you.Memphis fixed mine.
    02 GTP with mods 05 GP for DD
  3. #3 Re: prj wires and more
    GT Level Member reinke's Avatar
    Oct 2008
    cleveland, ohio
    wtf are prj wires.
  4. #4 Re: prj wires and more
    Jul 2008
    Quote Originally Posted by reinke View Post
    wtf are prj wires.
    Plug wires,I think he was trying to knock 2 questions out in one thread.The prj wire question should probably be in a seprate thread for the model of his car,to get a better answer or be seen by someone who can answer it.
  5. #5 Re: prj wires and more
    Oct 2008
    mascoutah, Il
    PRJ plug wires
    yeah I wasnt sure where to post, figured it was a audio question so I posted it here. Oh well.
    2002 GTP
    custom HOK paint
  6. #6 Re: prj wires and more
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    You got a ground loop some where.
    And never run a speakers on low pass that is there for sub woofer use only.
    Where you ground your system at?
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  7. #7 Re: prj wires and more
    Oct 2008
    mascoutah, Il
    Quote Originally Posted by Toofastgs View Post
    Drilled a new ground in the trunk. Metal to metal.
    Edit: it was the ground on the hu, fixed. Still have alternator whine however.
    2002 GTP
    custom HOK paint
  8. #8 Re: prj wires and more
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    i have that same thing coming from my speakers but its not my system, the aftermarket radio is what's making it in mine but i'm not too worried about it
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  9. #9 Re: prj wires and more
    Jul 2008
    Quote Originally Posted by offroadfury6 View Post
    dont lie its the Kicker setup,Memphis FTW i had too lol j/k
  10. #10 Re: prj wires and more
    Aug 2008
    Fayetteville, NC
    lol funny...
  1. zzp wires vs. prj wires...
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2008, 10:18 PM
  2. Plug wires
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2008, 03:12 PM
  3. MSD Wires
    By PonchoDvr4Lfe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2008, 07:14 PM
  4. 2 unsused wires...what are they for...?
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 02-14-2008, 01:11 PM
