Thread: Finding +and- on a cap
Results 1 to 20 of 36
  1. #1 Finding +and- on a cap
    GT Level Member WhiteGT's Avatar
    May 2008
    Ontario
    Hi everyone.
    I have an old 1 farrad accucap that I was considering installing when I get new subs. Only problem is that there is no indication on the cap which set of terminals is +and-. I have not used it in a few years and can't remember which is which. Is there a way to check this with a multi meter or something? Thanks for any help!
  2. #2 Re: Finding +and- on a cap
    GT Level Member jasonball's Avatar
    Nov 2008
    ft. mitchell
    my suggestion is don't even use it. they don't really do anything.
  3. #3 Re: Finding +and- on a cap
    May 2008
    Ontario
    Quote Originally Posted by jasonball View Post
    I have it already, it can't hurt anything to have it and The display is kinda cool, so if I can figure out which way it hooks up properly I would like to use it.
  4. #4 Re: Finding +and- on a cap
    Barksdale AFB, LA
    Quote Originally Posted by WhiteGT View Post
    Actually, it can. Once it becomes discharged (after the first hit), it will do nothing but add a load to your alternator instead of helping it.
    2009 Subaru Impreza WRX STI
  5. #5 Re: Finding +and- on a cap
    May 2008
    Ontario
    Quote Originally Posted by Sabrewings View Post
    So what purpose do they really serve then? Just wondering. A friend of mine has a 5 farrad cap on his system which consists of 1 3000 watt power accoustic amp 2 12 p accoustic subs and an alpine 4 channel and the lights still dim on bass hits?
  6. #6 Re: Finding +and- on a cap
    A cap can be very helpful with minor light dimming/voltage drop situations, as it stores power and discharges it very quickly...much quicker than a battery. A cap is essentially a battery, but it can charge up much faster, discharge energy much faster and take a lot less toll on your charging system overall (not to mention it weighs a fraction of a batteries weight)....any more than a 1-2f cap is useless, and likely will start to over-tax your charging system (much like additional batteries)...the absolute one and only thing that makes power is an alternator, batteries and caps simply store power... so if your low on voltage upgrade your alternator!
    As for your cap, i really can not see there being no markings unless the stickers got peeled off or something??...hooking up a cap backwards can be dangerous, so i would look into the make and model try pulling up some information on it, perhaps e-mail the company.
  7. #7 Re: Finding +and- on a cap
    GT Level Member reinke's Avatar
    Oct 2008
    cleveland, ohio
    use a test light and ground it to you cars chassis and touch the probe to both ends. whisch ever on lights up is the pos.
    like it has been stated it WILL cause damage. they are pointless besides for the display. i have one in my competition truck only for the voltage gauege. it is hooked up with 14 awg wire.
  8. #8 Re: Finding +and- on a cap
    SE Level Member Hayden's Avatar
    Aug 2008
    Michigan
    [quote=reinke;112550]use a test light and ground it to you cars chassis and touch the probe to both ends. whisch ever on lights up is the pos.quote]
    That will only work if the cap has a charge
    I say toss it out. you can probably take the digital volt meter off of it and wire it in anywhere.
    2008 Grand Prix + Kenwood KVT815DVD, Kicker SXRC Controller, Kicker SX 1250.1, Kicker (2) 12" L7's, Kicker SX 900.4, Kicker RS65.2 Components in front. Infinity Refs 9623i 6X9's in rear
  9. #9 Re: Finding +and- on a cap
    Oct 2008
    cleveland, ohio
    usually a capacitor will hold some of its charge no matter what. you only need 1 volt to turn a test light on.
  10. #10 Re: Finding +and- on a cap
    Aug 2008
    Michigan
    He said he hasnt used it in a few years though. I guess it's worth a try
  11. #11 Re: Finding +and- on a cap
    Barksdale AFB, LA
    Bragging rights? Not much else.
  12. #12 Re: Finding +and- on a cap
    Oklahoma
    Well caps do serve a useful purpose, even in automotive applications. The one big thing they are good at as stated already is power storage. Thats why they are used so widely in audio applications, they fill the gap where the battery/alternator cant keep up, but they do have limits and as mentioned you can get one big enough that it could potentially put too much of a load on the alternator.
    The next thing they are good at is filtering AC noise out of an electrical system. In a car that is powered by DC that is a really good thing, particularly with all the AC noise that can be introduced into the system by various components. Anyone ever hook up an oscilloscope to an automotive system? It can be quite loaded with AC noise.
    Usually with capacitors, they are marked in some way. Smaller circuit board one have a lead that is longer than the other or marked on the part itself in some way. In larger ones, Ive seen + and - signs stamped into the terminals themselves.
    Another way to determine it (someone already mentioned the test light) would be to also try using a multimeter set the measure DC voltage. The red lead is positive, the black is negative or ground. Touch the two terminals, when the voltage reads a positive voltage (i.e., not -12 or something like that) then the terminal the red lead is touching is the positive terminal.
    Capacitors can recharge themselves on the static electricity in the air. In electronics school we were taught to keep a resistor across the terminal of large capacitors. At that time a large capacitor was 200,000 micro farads. I can only imagine the charge full farad or multi-farad capacitors can store from just the static electricity in the air.
    Ive seen a 100,000 micro farad capacitor arc pretty darn good from just the charge built up from static.
  13. #13 Re: Finding +and- on a cap
    May 2008
    Ontario
    I finally found the markings under the terminals. Caught it in just the right light to see them. No idea why they would be so difficult to find since it would be dangerous to hook it up wrong. Thanks to everyone for all the info!
  14. #14 Re: Finding +and- on a cap
    Oklahoma
    yeah, you'd think they would make that easier to see.
  15. #15 Re: Finding +and- on a cap
    Nov 2008
    Chicago
    _nick_ and Synthetic posted the most useful and accurate info in this thread IMO. A multimeter is the best way to go about testing something like this. I imagine that the diode test on the meter would work quite well and quite safely for a capacitor
  16. #16 Re: Finding +and- on a cap
    Barksdale AFB, LA
    Diode test would do nothing. A capacitor is an open no matter how you test it. You will never get continuity since there is no continuity.
    Small caps inside the electronics for filtering are good. They also make up part of band-pass filters. Using them to supplement power is a waste. Sorta like putting a bandaid on a broken leg. If you alternator can't keep up, you should put the money towards a higher output alternator.
  17. #17 Re: Finding +and- on a cap
    Oct 2008
    cleveland, ohio
    actually a secondary battery would be a better moved. his stock alternator has roughly 25 extra amps that are not needed at speed. he would see a better imporvement if he picked up a kinetik or a powermaster battery.
  18. #18 Re: Finding +and- on a cap
    Barksdale AFB, LA
    Second battery is worthless too. Batteries are 12v. Usually the car's electrical system is above that. So, the battery won't do anything until the alternator is strained and the system's voltage drops to 12v. Then the batteries will keep it from dropping any lower until they are dead. Only problem is that when the load lifts now the batteries are drawing current as they try to recharge.
    The only real answer to the problem is a better alternator.
  19. #19 Re: Finding +and- on a cap
    Nov 2008
    ft. mitchell
    if you go with any secondary source use a batcap.
    What is a BATCAP?
    A conventional battery, as we all know has a positive and negative terminal. The chemical reaction within creates a flow of electrons, causing an electronic device (in this case an amplifier) to work. The stiffening capacitor is similar to a battery in that it stores a charge. The fundamental difference is it cannot create electrons. It can only store and supply (discharge) them upon demand. The advantage with a capacitor is that it discharges in one twenty thousandth of a second, unlike a battery that does in one second. The battery therefore cannot discharge fast enough to effectively supply the amplifier and this is the reason for "power sags."
    WAKE UP! Don't fall asleep just yet, we're getting to the exciting part!
    The XSTATIC BATCAP© is simply a battery that can discharge just a s quickly as a capacitor. Therefore, you have a constant supply of electrons that will discharge at lightning speed. This puts less strain on your stock alternator and battery. It also recharges faster than a conventional battery since the internal resistance is low. How about the install? Well I'm sure you can find a place to put this 2.5lb. baby and his 5lb. big brother. Don't let the size fool you though. These BATCAP's can crank your car, and you can bet we put that to the test!
    The cost is another remarkable feature since the 300 model costs the same as a "High End" stiffening capacitor and the 400 model costs a little more. Remember, "good things come in small packages." (I was going to say that "SIZE" doesn't matter but, let's not offend anyone now.) Oh, by the way, the fact that the BATCAP© is capable of discharging in a RUSH over a 5-10 second period SCREAMS three letters, "SPL!"
  20. #20 Re: Finding +and- on a cap
    What is a BATCAP?
    batcaps are a good choice....A capacitor serves as a very good buffer for those sudden voltage drops hon hard bass notes. Its not the fact that your car doesnt have enough power for your system, its the fact your alternator has a 'lag' time in delivering the voltage so suddenly, so the alternative is to fall back on your battery, which runs at a lower voltage than your alternator, so you get the ligh dimming with the fluctuating voltage. (remember, your battery has a HUGE amount of current to deliver, but at a lower voltage than your alternator so you get the light dimming) A cap buffers this out by storing a large amount of energy at the alternators voltage, and discharging and recharging it very quickly iliminating the need to fall abck on your batteries current. Wise installers always say "the battery is to start your car and use electronics/lights with the car turned OFF..once your car is running it should serve NO purpose"
  1. I just had to share this finding
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 10-04-2008, 12:00 AM
  2. Help finding parts!
    By Dboy23 in forum Visual/Body Modifications
    Last Post: 09-17-2008, 11:39 PM
  3. need help finding an old post
    By TyroElite in forum Off Topic Discussion
    Last Post: 06-05-2008, 09:07 PM
  4. Need Help Finding Forged Pistons
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2008, 09:20 AM
  5. Help with finding sway bars for 05
    By John_Shughart in forum Brakes/Suspension/Chassis
    Last Post: 03-25-2008, 11:42 AM
