Thread: Reusing camaro speakers
Results 1 to 2 of 2
jasonnovak Reusing camaro speakers 12-01-2013, 07:50 PM
jasonnovak Re: Reusing camaro speakers 12-01-2013, 09:19 PM
  1. #1 Reusing camaro speakers
    Oct 2013
    WI
    On my 99GTP I thought the door speaker was blown because it was really quiet, but it turns out it had a Delco 4ohm speaker in it (from 97-98 I think instead of proper 2ohm Bose, was in an accident)
    I have some speakers 6.5 factory speakers from my camaro with a "monsoon" style - 2 ohm speakers and a factory amp.
    The door speakers appear to have a unique 4-pin connector for individual woofer/tweeter. Can I just solder on standard factory end to one set of terminals and then jumper red/red and black/black to the tweeter at the other end? Is that going to change the ohms and mess up the volume level as well?
    The other option is the use the factory 6.5 "subwoofer" (also 2 ohm) from the camaro sail panel - it already has the correct end, it's a bit deeper than the regular speaker, though I think the separate grand prix factory tweeter may be, if so I'd need to replace it or at least swap it from the other door
  2. #2 Re: Reusing camaro speakers
    Oct 2013
    WI
    I see the grand prix factory speaker has a capacitor on the lead to tweeter, could reuse on the camaro speaker to the built-in tweeter terminals? It appears the camaro is 2ohm woofer/4 ohm tweeter, and gp tweeter is 6 ohm
  1. pioneer ts G1642R speakers into front doors speakers?
    By thomasd2010 in forum Audio, Security & Visual Electronics
    Last Post: 02-03-2013, 10:16 AM
  2. Reusing valve cover gaskets
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-27-2011, 01:38 AM
  3. Any possibility of reusing low mileage LIM gasket?
    By benner in forum General Tech Discussion
    Last Post: 09-13-2011, 07:43 AM
  4. Reusing Oxygen Sensors
    By mechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 10:44 PM
