I was replacing the steering wheel controls in my 99 GTP, what what I gathered you just pry it up and then have just enough space (one inch?) to disconnect the connector. This isn't what I found when I removed mine, the cable is very short and doesn't extend beyond the wheel. Probably lucky I didn't rip the end off when I removed it, there doesn't seem to be an slack in the cable. I'm wondering if my cable is perhaps pinched and shorter than it should be? I couldn't find any good pictures. If I remove my airbag I think I may be able to fix it? It doesn't seem to be possible to reconnect the switch atm. The connector won't extend out any further than in the pic
