Thread: Steering wheel controls, wire too short? (pic)
Results 1 to 5 of 5
  1. #1 Steering wheel controls, wire too short? (pic)
    Oct 2013
    WI
    I was replacing the steering wheel controls in my 99 GTP, what what I gathered you just pry it up and then have just enough space (one inch?) to disconnect the connector. This isn't what I found when I removed mine, the cable is very short and doesn't extend beyond the wheel. Probably lucky I didn't rip the end off when I removed it, there doesn't seem to be an slack in the cable. I'm wondering if my cable is perhaps pinched and shorter than it should be? I couldn't find any good pictures. If I remove my airbag I think I may be able to fix it? It doesn't seem to be possible to reconnect the switch atm. The connector won't extend out any further than in the pic
  2. #2 Re: Steering wheel controls, wire too short? (pic)
    they are just really short. Mine were the same way.
  3. #3 Re: Steering wheel controls, wire too short? (pic)
    Oct 2013
    WI
    How do you connect them? When I get my switch low enough into the wheel the connector touch the switch the hole is fully filled by the switch so I can't nudge it into place with a screwdriver
  4. #4 Re: Steering wheel controls, wire too short? (pic)
    I used a tiny screwdriver
  5. #5 Re: Steering wheel controls, wire too short? (pic)
    Oct 2013
    WI
    A quick follow-up, the left side is definitely too short to re-install. I took out the right side and cable reached just up to the top of the wheel where the other is well below.
    Normal?
    Pinched/short?
  1. Steering Wheel Controls Wire.
    By Brammer in forum General Grand Prix Discussion
    Last Post: 10-21-2013, 07:04 AM
  2. is this what i need to keep my steering wheel controls?
    By Stevie in forum Audio, Security & Visual Electronics
    Last Post: 10-11-2013, 03:38 PM
  3. Steering Wheel Controls....
    By RedGTDT in forum Audio, Security & Visual Electronics
    Last Post: 07-18-2010, 09:59 PM
  4. cant wire adapter for the steering wheel controls
    By chuy09 in forum Audio, Security & Visual Electronics
    Last Post: 12-18-2009, 02:50 PM
  5. steering wheel controls?
    By CrazyCanuck in forum Audio, Security & Visual Electronics
    Last Post: 02-16-2009, 12:42 PM
