Thread: Saab Dual coil sub wiring
Results 1 to 5 of 5
  1. #1 Saab Dual coil sub wiring
    Apr 2012
    NE Ohio
    I just scored a Harmon Kardon sub woofer from a Saab 9-3. This will fit in the right rear trunk cubby. I Know how to solder well but I have little
    knowledge of audio systems and I'm wondering where to wire it up to
    I've got a 2003 GTP with Bose and OnStar (OnStar removed). The Amp is stock and I've got a base level Tape player HU (for audio input) from some
    other GP.
    Impedance: 2 x 2.0 ohm because it's got a dual voice coil
    Amplifier power: 2 x 22W
    Frequency range: sub-bass
    I Have an aftermarket 1 din Head unit (I forget specs) if I have to use that and if I have to install an aftermarket Amp that's ok too. All
    Aftermarket parts should be HQ and aiming cor clarity not power/loudness. I am aware of the gmos-04 radio adapter that may be necessary.
    Any help?
  2. #2 Re: Saab Dual coil sub wiring
    This guy.
    Someone halp this guy.
  3. #3 Re: Saab Dual coil sub wiring
    Apr 2012
    NE Ohio
    Tested Sub: works.
    wires have been identified.
    just need to know what to tap it into
  4. #4 Re: Saab Dual coil sub wiring
    Apr 2012
    NE Ohio
    I plan on tapping into the 6X9s I guess and then run that through a crossover to the sub.
    Is this the best way to run this sub with minimal extra equipment?
  5. #5 Re: Saab Dual coil sub wiring
    Sep 2011
    Arkansas
    Ehhh... that'd work. You would use a line output converter.... not a crossover. Small in-line capacitors can be used as high pass or low pass filters, although an aftermarket amplifier with even a rudimentary LPF will mitigate the need for those. You could use some on your interior speakers to help filter some bass out without turning down the setting, which would effect your sub. This is assuming you want to keep the stock headunit. Honestly though, go ahead and install an aftermarket amplifier... it'll give you more options once you get tired of the output of that sub (I'm betting that you will). Honestly, with your tendency to prefer quality over volume, a single sealed 12 would do wonders. I'm partial to Obsidian Audio subs for awesome sealed performance. If you wish to spend a bit more, check out the TC epic subs on parts express. Of course, the sky's the limit here. I bet that a single Obsidian 12 in 1.5 cube sealed enclosure on 500 rms or so would blend very well (with proper tuning), as well as getting a little rowdy for your frisky times. Whatever you decide to do, best of luck to ya.
    Sent from my A200 using Tapatalk 4
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  1. Went out to get another Saab and came back with this.
    Last Post: 11-08-2013, 02:32 PM
  2. Pulled on by a SAAB?
    By CapnBreakAlot in forum Track Sessions and Kills
    Last Post: 08-05-2013, 05:48 AM
  3. SSEi VS Stage2 Saab
    By 2003 SSEi in forum Track Sessions and Kills
    Last Post: 10-03-2012, 10:59 PM
  4. Raped by late 90s Saab
    By RamonGTX in forum Track Sessions and Kills
    Last Post: 04-18-2011, 01:09 AM
