Thread: Amp power cable pass ..08 grand prix
Results 1 to 18 of 18
  1. #1 Amp power cable pass ..08 grand prix
    el paso
    can any body help im just trying to find where i can pass the power cable from the batterey to the interior ?
    Also i have a problem with my stereo its only on when the headlights or fog lights are on. I changed it from the stock ,but i guess i didnt wire it right
    anything will help thanks
  2. #2 Re: Amp power cable pass ..08 grand prix
    Aug 2008
    KCMO
    there is a gromet in the passenger floorboard run it through there. as for the wiring go back and double check every thing first and then go from there.
  3. #3 Re: Amp power cable pass ..08 grand prix
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    yes peel back ur carpet in the passenger floorboard. u should see the hole with wires in it. go around to ur engine bay, find the hole, stick a screwdriver in it to stretch the rubber boot, and there u have it. and Yeah, double check ur wiring. the radio should go off when door is opened, just like factory.
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  4. #4 Re: Amp power cable pass ..08 grand prix
    Sorry to hi-jack the thread here but, I've got a 2002 and on the firewall side of this grommet there is a rubber hosing that the wires travel into.
    Are you guys suggesting that I should cut this?
  5. #5 Re: Amp power cable pass ..08 grand prix
    Aug 2008
    Fayetteville, NC
    nah u dont have to cut it just stick a screw driver in it and wiggle it around to loosen up the boot, stretch it.
  6. #6 Re: Amp power cable pass ..08 grand prix
    So i take it its a very short boot then? I'm looking to run two 4 guage cables through it so stretching 3 feet of rubber while its on the car would be kinda difficult.
  7. #7 Re: Amp power cable pass ..08 grand prix
    Aug 2008
    Fayetteville, NC
    well I just stretched mine cause I wanted it to keep its purpose of keeping my firewall sealed from the cabin of the car. I mean its ur car, do what u have to, It was a tight lil hole for me, maybe u can make it though.
  8. #8 Re: Amp power cable pass ..08 grand prix
    London Ont, Canada
    hell even get a short piece of PVC pipe cram it in the hole and feed thru the pipe then remove when done, problem solved!
  9. #9 Re: Amp power cable pass ..08 grand prix
    Aug 2008
    Fayetteville, NC
    ^^^ tape wire to a metal clothes hanger and pull thru will work too
  10. #10 Re: Amp power cable pass ..08 grand prix
    memphis
    Quote Originally Posted by offroadfury6 View Post
    That's how i did mine...i keep a hanger so i don't have to keep get a new..it's a great tool..lol
  11. #11 Re: Amp power cable pass ..08 grand prix
    Indy
    dude i had this same problem. that thick hard piece of rubber on the floorboard side will wiggle out of there. then when u get it out just simply poke a hole in the remaining grommet and attatch your power wire to the object you cram thru the hole and you will see it in the engine compartment. this is the only way youu are gonna get it thru. once you get the line ran simply pull your back seats down via the strap in the top corner of your seats. i mounted my amp on the back of the seat this makes easier to get to the amp and also better aesthetically.
  12. #12 Re: Amp power cable pass ..08 grand prix
    el paso
    wow i dint expect to be an essay in here lol
    but thanks guys for the info
    anybody else wonderin the rubber thing is cut into like 2 lil squares but you canttell cuz its so tight and its kinda hard to see it from the ingine cuz its like curving in but just tick somthin through then you should see it ..
  13. #13 Re: Amp power cable pass ..08 grand prix
    Indy
    Get some pliers and pull that piece out of that rubber piece on the floorboard that's holding that wire. Get ya a long screwdriver nd tape your power wire to it. Cram it thru the whole and reach down and grab that sucker and hook it to the battery
  14. #14 Re: Amp power cable pass ..08 grand prix
    London Ont, Canada
    yeah, would - i think he's concerned with having to feed it thru the rubber and damaging something..
  15. #15 Re: Amp power cable pass ..08 grand prix
    Aug 2008
    Fayetteville, NC
    nah, i'd go with the clothes hanger deal. and pull that ***** thru!
  16. #16 Re: Amp power cable pass ..08 grand prix
    Its done. Best part was I pushed about a foot of cable into the engine compartment only to have it all end up on the ground. Out came the coat hanger again...
    If you've got a 97-03 I would think you don't need to take the back of the rear seats out, just follow the cables going into the trunk and they should feed right through. No need to even cut the carpet in the trunk.
  17. #17 Re: Amp power cable pass ..08 grand prix
    Feb 2009
    Virginia
    I haven't read anybody's reply...but I have pictures Maybe it'll help the next person to come through?
    Grand Prixs Of North America • View topic - Car Audio Install
    Just finished installing on 04 GTP Comp G
  18. #18 Re: Amp power cable pass ..08 grand prix
    Oct 2013
    Canada
    *Oringinal post removed*
    Additional info to use passenger side firewall grommet. (97-03 grand prix)
    Use screwdriver to pry INSIDE out. As in inside the black surrounding soft rubber. You can then use pliers if you want to grab the piece and pull it out. You are removing a thick 1 1/2 inch rubber plug with a split in the middle that needs to be removed before running a coat hanger through the firewall grommet.
    (note* the split in the rubber piece is connected on far side of the wires so you have to rotate after pulling out to get it off. You will see this very easily)
  1. Please help with power cable for amp
    By blazer2002 in forum General Tech Discussion
    Last Post: 06-05-2009, 05:54 PM
  2. 2000 Grand Prix A/C Not Getting Power
    By neoseeker191 in forum General Tech Discussion
    Last Post: 05-21-2009, 07:13 PM
  3. 97 grand prix power options issues
    By redspace in forum General Tech Discussion
    Last Post: 03-18-2009, 05:34 PM
  4. power cable from batt
    By flipzat in forum Audio, Security & Visual Electronics
    Last Post: 03-03-2009, 12:15 PM
  5. Window cable?? 98 Grand Prix GT 4 door
    By markh in forum General Tech Discussion
    Last Post: 10-13-2008, 05:36 AM
