Thread: MTX RT8PT Powered Sub
Results 1 to 5 of 5
  1. #1 MTX RT8PT Powered Sub
    SE Level Member killuminati's Avatar
    Oct 2013
    Ohio
    So I just purchased a MTX RT8PT (http://www.crutchfield.com/p_236RT8P...RT8PT&skipvs=T). I just wanted a slight bass increase that was not too overwhelming. Has anyone installed something like this before to the stock head unit? If so, anything I need to know to make it easier? I bought an a extra amplifier connection cable because this does not come with one. I'm assuming this is just wired straight to the battery. Pardon my ignorance, but I am a noobie to car audio, so I am still learning.
    My other question is, do I just splice this sub into the rear 6x9's? Or do I run a separate wire all the way to the head unit. Thanks for your help!
  2. #2 Re: MTX RT8PT Powered Sub
    Omaha, NE
    You can get an aux output for the factory head unit here: http://pac-audio.com/productSearch.a...28&Model=Grand Prix&ModelId=1569&Year=2005&YearId=16
    That will prevent having to splice into the rear speaker wires, and makes for a cleaner install in my opinion.
  3. #3 Re: MTX RT8PT Powered Sub
    Oct 2013
    Ohio
    I actually just purchased one of these.
    http://www.onlinecarstereo.com/CarAu..._AAI-GM24.aspx
    So because I have this now, I should run the sub right to the head unit instead of splicing?
    If I do this, will the sound only run through the AUX? Or will it run on radio/cd/etc.
  4. #4 Re: MTX RT8PT Powered Sub
    Omaha, NE
    There should be no splicing requred on the speakers. You will essentially want to run the setup the same as if you had an aftermarket head unit with outputs on it. The sound will run through both the speakers and amp simultaniously.
  5. #5 Re: MTX RT8PT Powered Sub
    Oct 2013
    Ohio
    Only thing I'm slightly confused about is that I thought this adapter was strictly for auxiliary inputs, not for speakers. Does this adapter have somewhere on it that will connect to a sub and amp?
  1. finally got me a l67 powered car!
    By blazer316 in forum Introductions/Noob Questions
    Last Post: 06-03-2010, 03:53 PM
  2. Parts for the gxp and ls4 powered cars.
    By Panther427 in forum 5.3L V8 (LS4)
    Last Post: 07-27-2009, 07:06 AM
  3. Safely Modding Your 3800 Powered Car!!
    By blueguy in forum General Tech Discussion
    Last Post: 07-05-2009, 10:43 PM
  4. It's a Bonneville, but 3.8 powered
    By myfirstbonnie in forum Introductions/Noob Questions
    Last Post: 04-06-2009, 12:48 PM
  5. Anyone a Hydrogen Powered Grand Prix
    By 03GPScottyd in forum Off Topic Discussion
    Last Post: 09-24-2008, 03:05 PM
