Thread: How do you access the rear of the stereo 05 GP GXP
Results 1 to 11 of 11
  1. #1 How do you access the rear of the stereo 05 GP GXP
    SE Level Member killuminati's Avatar
    Oct 2013
    Ohio
    I purchased a conversion kit to play an MP3 player through my stock stereo. I was just wondering if anyone had a how-to or any good information on how to get to the back of the stereo in a 2005 Grand Prix GXP. Thanks for all the help.
  2. #2 Re: How do you access the rear of the stereo 05 GP GXP
    typically you take the dash trim off, most cars its got push clips holding it on, so grab a corner and pop the clips, then un bolt the radio and slide it out, un hook the plugs on the back of it.
  3. #3 Re: How do you access the rear of the stereo 05 GP GXP
    Aug 2011
    'Merica
    Where are you in Ohio? I believe you have to pop the ring around the ignition first then pop the dash off around the radio.
  4. #4 Re: How do you access the rear of the stereo 05 GP GXP
    Oct 2013
    Ohio
    Youngstown Area. Is there a special tool to pop off the clips? Or should I just use a screwdriver. I just don't want to end up with broken clips everywhere and a bunch of extra screws when I'm done with it lol.
  5. #5 Re: How do you access the rear of the stereo 05 GP GXP
    GT Level Member WolvesSoulZ's Avatar
    Québec
    It's all clips, use a small flastnose screwdriver to pop the ring around the ignition, then use your hands, and pop the bottom of the trim and work your way to the top of the trip. Carefully when you unclip the top as the DIC is connected by a short electrical connector, un-plug it from the dic, discard the trim, unscrew the radio, pull it out, do your stuff, reverse then after.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  6. #6 Re: How do you access the rear of the stereo 05 GP GXP
    GTP Level Member simbah's Avatar
    Lala land
    Once you get the trim panel off you have to remove the screws from the storage compartment first then the HVAC controls then the radio, I know it's stupid but that is the GM design here.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  7. #7 Re: How do you access the rear of the stereo 05 GP GXP
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
    Quote Originally Posted by Below Average Joe View Post
    You don't even need a screwdriver to pop the trim off. Mine comes off with fingertips pulling. You'll need to either unplug the DIC or swing the trim panel out of the way. Eight Phillips screws later, the back of your OEM head unit will be accessable.
    Don't break the ignition bezel. The only way that comes is with the cylinder and it ain't cheap.
  8. #8 Re: How do you access the rear of the stereo 05 GP GXP
    Oct 2013
    Ohio
    Quote Originally Posted by douger View Post
    Just so I know, use flathead on the bottom of the ignition ring? Lift up and it should pop off safely?
  9. #9 Re: How do you access the rear of the stereo 05 GP GXP
    May 2012
    Cedar Rapids, Iowa
    Yeah but try not to stick the screw driver in all the way, otherwise your passkey Excitor could break then you won't be able to start the car.
    This happened to me.
  10. #10 Re: How do you access the rear of the stereo 05 GP GXP
    Oct 2013
    Ohio
    Quote Originally Posted by vandezand View Post
    Good to know, thanks.
  11. #11 Re: How do you access the rear of the stereo 05 GP GXP
    Omaha, NE
    Start pulling the trim from the bottom, its a bit easier starting with the area under the empty compartment.
  1. Stumped and have no access to a scaner
    By MoBoost in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-06-2011, 01:51 PM
  2. Can't access site from pc
    By Slick2500 in forum Forum Bugs/Suggestions
    Last Post: 11-20-2010, 12:19 AM
  3. Cannot access chat.
    By rynoman03 in forum Forum Bugs/Suggestions
    Last Post: 11-09-2010, 05:50 PM
  4. access to gauges???
    By kjclawson in forum General Tech Discussion
    Last Post: 08-16-2009, 02:51 AM
  5. Anyone have access or do CNC Machine work?
    By SD GTP in forum Off Topic Discussion
    Last Post: 03-22-2008, 10:35 PM
