Where are you in Ohio? I believe you have to pop the ring around the ignition first then pop the dash off around the radio.
Youngstown Area. Is there a special tool to pop off the clips? Or should I just use a screwdriver. I just don't want to end up with broken clips everywhere and a bunch of extra screws when I'm done with it lol.
You don't even need a screwdriver to pop the trim off. Mine comes off with fingertips pulling. You'll need to either unplug the DIC or swing the trim panel out of the way. Eight Phillips screws later, the back of your OEM head unit will be accessable.
Don't break the ignition bezel. The only way that comes is with the cylinder and it ain't cheap.
