Thread: bose removal
Results 1 to 7 of 7
  1. #1 bose removal
    SE Level Member Slueth66's Avatar
    Nov 2008
    Iowa
    how can you bypass or remove the bose system when installing a new head unit? What will i need to do so?
  2. #2 Re: bose removal
    Jan 1970
    Maquoketa, Iowa
    Do you have new speakers to put in? Or do you still want it to play through the bose amp and speakers?
    When I did mine I just tore everything out and put all new in. It was cheaper to do at the time than buying all the adapters and not having to run wires from the headunit to the bose amp for every speaker.
    The easy way would be to get the adapter. I ran all new wires to the headunit when I did my install, took a while.
  3. #3 Re: bose removal
    Nov 2008
    Iowa
    i dont want the bose amp to be the amplifier i use. i want to run the speakers off a new head unit. can i buy the adapter and just remove the amplifier and reconnect all the wires that run into and out of the amplifier?
  4. #4 Re: bose removal
    GT Level Member 98daytona500's Avatar
    Nov 2008
    st louis
    what year? onstar??
    99 buick regal gsx..headerz, 3" motor back exhaust , lowered on B&G springs, transgo shift kit, solid offset front motor mounts, 3.2 mps, fuel pump rewire, zzp h/l cam, tinted headlights and tails, 5% tint all around zzp s2 alt booster, alt rewire, al103, jmb, ported blower, machined lim
  5. #5 Re: bose removal
    Nov 2008
    Iowa
    2001 gt with onstar
  6. #6 Re: bose removal
    St. Louis Mo.
    Personally for me, at first, when I got my Pioneer 6000 HU, I used the Bose Amp in conjunction with the Pioneer's output. I just tapped into the wire on the Bose amp and walla. It actually sounded pretty good, but of course I upgraded to "real" amps a few months afterwards.
    But if you want to use ONLY the HU's amp to run your speakers, you most certainly can. You will lose your onstar, but with your year model, they, GM, has phased out OnStar analog service and you can no longer use it anyways.
    Don't bother with one of those kits that will save your Onstar features. They are way to over priced for what little you keep. The only thing you are going to lose by bypassing your Onstar is some of the more annoying chimes. You will lose the chime that alerts you to when you have left your turn signal on and it has failed to automatically flip off. And that frankly is the only thing I have noticed a difference in. I still hear my turn signals "click" when I use them, and my door chimes still work when I open the door with the key still in the ignition.
    The base model plugin runs about $25 bucks. Here is a picture of mine when I coupled it to the Pioneer's connection.
    James Shafer
    St. Louis MO
  7. #7 Re: bose removal
    Jan 1970
    Maquoketa, Iowa
    I would go that route^^^
    When I did mine I put in all new speakers and completely rewired everything to the headunit. Took about a full day since it was my first install like that.
    The bose sucks because it has no bass, all highs. Go with the new headunit for now and if you still want some bass get a sub before you start tearing out speakers.
  1. Bose stereo problem
    By jiggar1964 in forum Audio, Security & Visual Electronics
    Last Post: 11-21-2008, 05:02 PM
  2. BOSE with a mind of its own....
    By armcclure in forum Audio, Security & Visual Electronics
    Last Post: 09-17-2008, 02:52 PM
  3. Bose?
    By flynn in forum Audio, Security & Visual Electronics
    Last Post: 08-16-2008, 04:24 PM
  4. 01 GTP W/ Bose package. Looking to Upgrade. Plz help :)
    By Freebeer187 in forum Audio, Security & Visual Electronics
    Last Post: 07-23-2008, 03:06 AM
  5. Aftermarket headunit install on BOSE system??
    By FoSHO99 in forum Audio, Security & Visual Electronics
    Last Post: 01-05-2008, 03:51 AM
