Yes you can run a higher ohm sub to a lower ohm rated amp no problem... the other way around is where you will run into issues... an ohm defines the resistance of electricity through a path... so a lower ohm rating means there is less resistance, and in turn more electricity will flow through said path. Which for speakers and amps means more power is used by the sub and drawn from the amp.
