yes 4 gauge is fine...you don't need secondary fuses just make sure you have a fuse on the power wire up close to the battery (any wire between the battery and the fuse is obviously not a fused link, so if it shorts out it will cause a fire) The only reason for line fuses is to protect against shorts in the power wire, amps have their own fuses for protection. Fused distribution blocks are pointless...
