Try this:
Locate the black-and-white programming connector wire located in the right-hand side of the trunk. Pull back the trunk's lining to access it. On the end, you will find a terminal in a plastic connector. Place this against a bolt or the trunk latch. You will hear the locks cycle. Press any button on the remote, and listen for the locks to cycle again. Repeat this step for all remotes
