Thread: Reprogram key fob
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #1 Re: Reprogram key fob
    Aug 2011
    'Merica
    Read this:
    Service Info shows the following.
    1989 Pontiac Grand Prix Page 8A-132-4 1990 Pontiac Grand Prix Page 8A-132-7
    Please update your copies of the Service Manuals.
    TROUBLESHOOTING HINTS
    Try the following checke before doing the System Diagnosis.
    1. Check LUGGAGE COMPARTMENT Fuse.
    2. Always check terminal contact before replacing any component.
    3. If door locks operate from the transmitter, but not form the door lock switches, check continuity of door lock switches and associated wiring for an open or a short. Repair/replace as necessary.
    4. If a second transmitter is available, try it. If it works, change the batteries in the first transmitter and try it again, If it still doesn't work, it is defective.
    5. Check portable transmitter battery terminals. They should be clean and make good contact with the battery.
    6. If in doubt as to the condition of the transmitter batteries, replace them with new ones. Measuring battery voltage with a DVOM may give misleading results.
    KEYLESS ENTRY MODULE PROGRAMMING PROCEDURE
    Do the following procedure whenever the Dats Encoder connector is grounded, the Keyless Entry Module is replaced, the portable transmitter is replaced or a second transmitter is added.
    1. Jumper the Data Encoder connector to ground. (all power door locks will lock and unlock)
    2. Operate transmitter by pressing a single button once. (all power door locks will lock and unlock)
    3. To program for a second portable transmitter, operate second transmitter by pressing a single button once. (all power door locks will lock and unlock)
    4. Disconnect Data Encoder Jumper Connector.
    5. Verify that the portable transmitter(s) operate door locks and luggage conpartment release.
    Try the following checks before doing the System Diagnosis.
    Do the following procedure whenever the Date Encoder connector is grounded, the Keyless Entry Module is replaced, the portable transmitter is replaced or a second transmitter is added.
  2. #2 Re: Reprogram key fob
    GTX Level Member Neil98gt's Avatar
    May 2011
    Kansas city
    Damn GM had keyless entry in 89?
    I thought that was an early-mid 90's thing.
    98 GT 2dr 116k, Sold
    07 Lexus ES350 Obsidian Black. Premium Plus package, sold
    2013 Hyundai Elantra GT
    2002 Grand Prix GT 4dr
  3. #3 Re: Reprogram key fob
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
    Quote Originally Posted by Neil98gt View Post
    According to my parts catalog, 1989 was the first year.
  1. Reprogram ECU?
    By GPGTdude12 in forum General Tech Discussion
    Last Post: 05-27-2011, 04:08 PM
  2. Enough mods for a PCM reprogram?
    By mousemonster1232 in forum General Tech Discussion
    Last Post: 01-27-2011, 11:42 PM
  3. pcm reprogram
    By bballa0740 in forum PCM Tuning
    Last Post: 08-28-2009, 08:14 PM
  4. $$$ How much reprogram the DIC?
    By corvetteii in forum General Tech Discussion
    Last Post: 02-16-2009, 08:56 PM
  5. PCM reprogram
    By sickofsoyo in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-04-2009, 01:35 AM
