Thread: HOW to remove AUTO HEADLIGHT at night? 2002 GTP
Results 1 to 20 of 22
biggt HOW to remove AUTO HEADLIGHT... 06-23-2012, 03:01 PM
gtpeddie Re: HOW to remove AUTO... 06-23-2012, 03:04 PM
Pontiac Man Re: HOW to remove AUTO... 06-23-2012, 04:01 PM
biggt Re: HOW to remove AUTO... 06-23-2012, 03:23 PM
gtpeddie Re: HOW to remove AUTO... 06-23-2012, 04:03 PM
Fivefingerdeathpunch Re: HOW to remove AUTO... 06-23-2012, 04:10 PM
Pontiac Man Re: HOW to remove AUTO... 06-23-2012, 04:17 PM
Pontiac Man Re: HOW to remove AUTO... 06-23-2012, 04:13 PM
matt5112 Re: HOW to remove AUTO... 06-23-2012, 04:13 PM
Bronco Boy Re: HOW to remove AUTO... 06-23-2012, 04:32 PM
matt5112 Re: HOW to remove AUTO... 06-23-2012, 04:39 PM
Bronco Boy Re: HOW to remove AUTO... 06-23-2012, 04:53 PM
matt5112 Re: HOW to remove AUTO... 06-23-2012, 04:55 PM
Bronco Boy Re: HOW to remove AUTO... 06-23-2012, 05:24 PM
KeithGTP03 Re: HOW to remove AUTO... 06-23-2012, 06:17 PM
biggt Re: HOW to remove AUTO... 06-23-2012, 11:11 PM
KeithGTP03 Re: HOW to remove AUTO... 06-24-2012, 12:19 PM
biggt Re: HOW to remove AUTO... 06-24-2012, 06:28 PM
biggt Re: HOW to remove AUTO... 06-24-2012, 07:03 PM
Bronco Boy Re: HOW to remove AUTO... 06-24-2012, 08:00 PM
biggt Re: HOW to remove AUTO... 06-25-2012, 02:32 PM
whitegt956 Re: HOW to remove AUTO... 07-08-2013, 03:38 AM
  1. #1 HOW to remove AUTO HEADLIGHT at night? 2002 GTP
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    Hi Guys, I want to know how to remove the AUTO HEADLIGHT at night, I want to manually turn my lights on at night!
    I dont have DRL's I already unplugged the MODULE on the driver side. I really suck in Electronics so ill have a friend to help me out.
    Don't tell me click the ebrake once because no! lol
    thanks
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  2. #2 Re: HOW to remove AUTO HEADLIGHT at night? 2002 GTP
    Jan 2012
    Philadelphia
    i have a 97 and i pulled the DRL and it worked fine. i heard another member say he pulled it on his 2002 and it made a clicking noise
  3. #3 Re: HOW to remove AUTO HEADLIGHT at night? 2002 GTP
    GT Level Member Pontiac Man's Avatar
    Sep 2011
    Decorah IA
    Quote Originally Posted by gtpeddie View Post
    That is just for day time lights I thot? I think you have to mess with the sensor in the dash in the upper center part of the dash by the little red light. I for got what you have to do to it.
  4. #4 Re: HOW to remove AUTO HEADLIGHT at night? 2002 GTP
    Jul 2010
    Montreal
    I already pulled it out and i had the clicking noise...
  5. #5 Re: HOW to remove AUTO HEADLIGHT at night? 2002 GTP
    Jan 2012
    Philadelphia
    i dont know what you mean lol
    i just know my lights are all manual now
  6. #6 Re: HOW to remove AUTO HEADLIGHT at night? 2002 GTP
    hmm, i thought just pulling the heatsink out behind the switch is what you need to do.
  7. #7 Re: HOW to remove AUTO HEADLIGHT at night? 2002 GTP
    Sep 2011
    Decorah IA
    That is just for day time lights.
  8. #8 Re: HOW to remove AUTO HEADLIGHT at night? 2002 GTP
    Sep 2011
    Decorah IA
    With the cars that click when you pull the DLR fuse you have to mess with that senser to make the lights manual. It senses when its dark and turns the lights on at night.
  9. #9 Re: HOW to remove AUTO HEADLIGHT at night? 2002 GTP
  10. #10 Re: HOW to remove AUTO HEADLIGHT at night? 2002 GTP
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by biggt View Post
    If you can stand having only your park lights coming on automatically, then do what I did: Alarm_Headlamp_Flash
    This "mod" is so easy that even those that suck at electronics shouldn't need a friend to help.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  11. #11 Re: HOW to remove AUTO HEADLIGHT at night? 2002 GTP
    Or you could look at the two links I posted.
  12. #12 Re: HOW to remove AUTO HEADLIGHT at night? 2002 GTP
    Jul 2010
    Coquitlam,BC,Canada
    Sorry for posting an alternative method.
    Besides, the resistor method didn't work for me (kept the headlights on all the time), and I have read of others with 2002 model years having the same problem.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  13. #13 Re: HOW to remove AUTO HEADLIGHT at night? 2002 GTP
    You really didn't read the links I posted then.
  14. #14 Re: HOW to remove AUTO HEADLIGHT at night? 2002 GTP
    Jul 2010
    Coquitlam,BC,Canada
    Read them many a time when I was doing the same thing last year that the OP is doing, thus how I came up with the solution I used.
    Your first link doesn't work on all cars. Your second link has nothing to do with the topic. Your point?
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  15. #15 Re: HOW to remove AUTO HEADLIGHT at night? 2002 GTP
    Houston
    I just pulled the DRL fuse and unplugged the connector right above the parking break. This module is the part that clicks when you remove the DRL fuse. Remove the plug and you now have manual lights and no clicking.
  16. #16 Re: HOW to remove AUTO HEADLIGHT at night? 2002 GTP
    Jul 2010
    Montreal
    The DRL fuse is the one in the fuse box right?
    and where is that plug located exactly? do i need to remove any plastic trims?
  17. #17 Re: HOW to remove AUTO HEADLIGHT at night? 2002 GTP
    Houston
    Yes, the DRL in the glove box, fuse box. No plastic trims need to be removed, just that carpet board piece that attaches to the "knee basher", if your car still has it.
    The module is on the driver side and it will have two plugs. Unplug the one on the right. If you look in the picture, that spring is the parking brake spring. And that larger module to the right, I believe is the Body Control Module. After you remove the DRL fuse, you should start hearing the clicking (if your car is on) and that will lead you to this module. In this picture the 2nd plug is already removed.
  18. #18 Re: HOW to remove AUTO HEADLIGHT at night? 2002 GTP
    Jul 2010
    Montreal
    and nothing will be caused if its not plugged?
  19. #19 Re: HOW to remove AUTO HEADLIGHT at night? 2002 GTP
    Jul 2010
    Montreal
    ok so i did it and everything looks and sounds good lol, is it normal the ebrake light wont come on ? i dont mind just checkin lol
  20. #20 Re: HOW to remove AUTO HEADLIGHT at night? 2002 GTP
    Jul 2010
    Coquitlam,BC,Canada
    Did you knock the wire off when you were rummaging around?
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. headlight problem 2002 se please help
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 04-06-2012, 01:02 PM
  2. How to safely remove headlight cover?
    By Juanmiguel in forum Visual/Body Modifications
    Last Post: 12-15-2009, 03:47 PM
  3. how do i remove the logo off my headlight covers
    By NEONNIGHT34609 in forum Visual/Body Modifications
    Last Post: 01-31-2009, 12:47 PM
  4. drls or auto headlight?
    By crywolf in forum General Tech Discussion
    Last Post: 11-25-2008, 11:56 AM
